I have around 330.00 for a GPU
RussianSensation
19,458
765
In all seriousness if your 8350 is running at stock speeds, buy an R9 290 and invest the difference in an after-market cooler like the Thermalright True Spirit 140 for $40.
You will want to overclock that 8350 to 4.7-4.8Ghz.
The amount of performance you are leaving on the table with a stock 3.6Ghz 8350 in modern games is huge. {see GameGPU.ru gaming results over the last 6 months}
Alternatively, you might even want to sell your entire AMD CPU/mobo combo, keep the DDR3 and get an i5+mobo. You might be able to squeeze such a possible upgrade if you get the MSI Gaming R9 290 for $240 and save $80-110 from not buying the GTX970. That would also be a great solution as even a stock i5 without any overclocking would outperform the FX8350 @ 4.7Ghz in games.
fleshconsumed
6,485
2,363
What others have said - buy aftermarket R9 290 for $220-240 and save the rest of the money for future upgrades. R9 290 has the sweetest price/performance ratio right now, anything cheaper is significantly slower, and you'd have to spend $100-300 more to get 10% performance gain.
