Actually, each brand still usually has one model just below the cheapest TrueHD/DTS-MA AVR that takes surround PCM over HDMI but doesn't decode the new streams. (IIRC the Xbox won't output surround PCM, but if the receiver won't take PCM over HDMI, it won't take any other audio over HDMI either.)Originally posted by: YOyoYOhowsDAjello
I think the easiest way to do this is to check if the receiver is capable of decoding Dolby TrueHD, DTS-HD MA, etc.
If it can do that, it must be able to take audio over HDMI. There are some models that do Linear PCM and such over HDMI and not decode those sound formats though, so there are some you might miss this way.
I believe most of the ones you should be looking at though have this ability now, so I think it's an ok method to use across brands.
I've found ProductWiki to be a nice source for this info -- faster than combing through manuals, anyway.
Originally posted by: Alienwho
If you are going to be spending ~$500 on a receiver, everybody is going to be recommending the Onkyo SR606 http://www.amazon.com/Onkyo-TX...Receiver/dp/B0015S8PGW . I myself will buy one when I can find a refurb for $225.
Originally posted by: NaOH
Actually, with the coupon code, I'd be better off with the 1909 at that price
6ave coupon code?
I don't see it, can you link me?
HD-DVDs on the 360 will play back in plain old DD-5.1 or DTS-5.1. You get to choose, in case your receiver is better with one or the other. There's also the option of stereo PCM, although I very much doubt this is "lossless" in any way, shape, or form. It's unfortunate that the 360 can't bitstream high bit rate (HBR) audio codecs or decode and output them as PCM-5.1/7.1, but that's life. IMHO, there is a perceptible quality difference between HBR audio and non-HBR audio, judging from my Blu-Ray discs.Originally posted by: s44
Only Blu-Ray/HD-DVD is in TrueHD (or DTS-MA). I'm not sure how the Xbox played back HD-DVDs, but I believe everything else (including games) is in plain old DD 5.1 -- makes sense, because not all Xboxes have HDMI.
