I have a really big problem, I need some help. Please! Edit: Pics of problem!
ViperMagic
2,260
Ok, I have this computer:
ECS K7S5A
ATI Xpert 2000 Pro
Creative Labs Modem Blaster
128 Megs of RAM
Duron 750
XP Home
Seagate Barracuda IV 40GB
It would boot to the desktop, there would be a little square around all the icons and cursor, start menu and such, filled with little red lines. I thought this was the motherboard, but I RMA'd it, and it still does it. I replaced the ATI Card with my GF3, still does it. Replaced moniter. Still. Now here are my theroys:
1. Somewhere the motherboard is touching the case
2. Bad PSU
Anyone have any ideas? My dad is flipping out on me becasue of this....... its his dads computer, and I'm supposed to be building it for him. I need some help... thanks
Jerboy
Banned
Oct 27, 2001
5,190
<< Ok, I have this computer:
ECS K7S5A
ATI Xpert 2000 Pro
128 Megs of RAM
Duron 750
XP Home
oh man I feel sorry for you :(
I had the same mobo as the one you're using and it was nothing but nightmare.
Dim
79
What OS are you using?
Have you tried reformatting/reinstalling?
Did you have any problem with the install?
ViperMagic
2,260
<< What OS are you using?
XP home
I have tried reformatting. It did it during setup too
Mltsao
Banned
Jan 8, 2001
1,280
<< I had the same mobo as the one you're using and it was nothing but nightmare. >>
Whats so bad about the K7S5A? I have built 5 systems with it with no problems at all.
cleverhandle
3,566
<< Whats so bad about the K7S5A? I have built 5 systems with it with no problems at all. >>
Nothing, it itself - I've built systems on it, too. But that is a rather unfortunate collection of components. Putting last-generation components together with Windows XP and an ECS/Duron combo is risky. Probably any one or two of those components wouldn't be a problem, but when you start adding up all those small probabilities...
Do you have Windows 2000 available? It might be more compatible than XP.
ViperMagic
2,260
No, But as of tommarow I will have Windows 98. I will try that
MUKid
93
Did you check that link that NesuD provided? It looks like that might be your problem -- the Barracuda is a UDMA 100, right?
ToBeMe
5,711
Viper.....I can tell you this much, that's a video card driver issue............I haven't used an Xpert in like forever........are XP drivers even available for it or are those 2K drivers? My advice........download all the drivers that may possibly work and try them all! Are there any conflicts in Device manager????
ViperMagic
2,260
<< Viper.....I can tell you this much, that's a video card driver issue............I haven't used an Xpert in like forever........are XP drivers even available for it or are those 2K drivers? My advice........download all the drivers that may possibly work and try them all! Are there any conflicts in Device manager???? >>
Those are XP drivers. And its done the same thing on a Xpert, GF2, and a VooDoo 3, AGP/AGP and PCI, respetivly. No conflicts in teh device manager.
DARRIN
2,756
You tried a different stick of RAM? If you have 2 stick try them one at a time.
SuperSix
<< You tried a different stick of RAM? If you have 2 stick try them one at a time. >>
This is the only thing that makes sense, as you have swapped vid cards/replaced mobo..
ToBeMe
5,711
OK........What about P/S then???? What is it and have tried swapping them???? Was going to mention RAM also......but, seeing as you have 128mb, I assume that it is a single stick right???? If not, I agree........try only one stick..........
ViperMagic
2,260
Its a single stick, and I've tried a different stick of SDR, and one of my own DDR sticks. Nothing
ViperMagic
2,260
I tried swapping PSUs too, same thing. Its an Emermax 350W, though I'm not sure on the wattage. Tommarow I'm getting another K7S5A-based system that works reasonably well, and I'm going to put the whole damn rig on that board. I'll let you guys know how it goes. Until then, any siggestions?
ToBeMe
5,711
Have you tried booting with just the video card? Taking out the modem and disabling the LAN/Sound?????
ViperMagic
2,260
<< Have you tried booting with just the video card? Taking out the modem and disabling the LAN/Sound????? >>
Yeah, I think so. I'm not sure if I did it right or not, though. I'll try it again in the morning
Thanks to everyone whose responded, and keep responding!
ViperMagic
2,260
<< Have you tried downloading the latest motherboard drivers? >>
I can't find them
Yeah, someone is going to make me look like an ass by getting them, but I couldnt find them when I looked
andrey
This has nothing do to with motherboard, RAM, hard drive, PSU, etc...
It is one of the following:
Video Card / Video Card Drivers
Monitor / Monitor's Refresh Rate
VGA Monitor Cable
Since you've already tried different video cards, that's pretty much eliminates the video card issue. Have you tried different monitor or running your monitor at different refresh rate and different resolution? What about monitor cable? Are you using BNC or VGA? Have you tried different one?
navir
12
your problem surely seems to be that last generation mobo.change it and see if it works.also check the drivers for your video cards
