I have a problem with my tv and need some help!
importdistributors
Ok this is what is going on, My tv's remote didnt work, so i bought a new remote, and that didnt work, i bought a universal remote, and programed it, and that didnt work, but my tv works without the remote. I usually put the tv on sleep at night so i can go to sleep and the tv turns off after the time limit is up. So no when i go to sleep the tv either stays on all night, or i have to get up and turn it off, then i cant sleep because i had to get up. Now the problem with not turning it on in the first place is becasue my brain keeps on thinking, and i cant relax. (too much stress) What should i do? I am contemplating suicide? would that help?
CLIFFS: TV does not work with any remote
Need to fix
Suicide is an option!
Originally posted by: CheapArse
suicide for you is a good course to take
WTF can you please elaborate, Why do you people have to make my life so feakin miserable, can you just tell me the best way to go? or do i have to waste more time doing that myself? JEEZ!
Well, I have never attempted to off myself before, but I hear DIAF is good. Another crowd pleaser is TPAD.
First you dont tell me, and now you are using abreviations that i am not familiar with!!!!!!!! AAAAAAAAAAAAAhhhhhhhh.
Maybe the best solution may be taking a bath (ala RING 2) with the TV and remote.
Seriously though, TV's are cheap - donate your's to Salvation Army for hurricane relief and get a new one ($100-$300).
With all the TVs they "found", I don't think they need anymore
I suggest dropping the TV on your head, preferably from two or three stories up. Attach a rope to it and pull, that should do it.
DIAF = Die in a fire.
TPAD = Take pills and drown.
THat is too much work!! I forgot to mention im lazy, but i thought you would have assumed.
Originally posted by: YOyoYOhowsDAjello
Maybe the remote sensor is covered up / damaged?
if it is damaged, is there anything i can do to repair it?
Probably not on your own.
Is this an expensive tv? You'd probably have to take it in to get it worked on. If it's a POS tv, then it probably makes more sense to just get a new one.
