Build Complete I have a parts kit picked out, but I want some input from The Collective!
Tech Junky
3,825
1,343
Only input would be watch for deals on the higher end x670e boards. I picked up one for $160 that was an Amazon used that works perfectly. Prices right now are inflated a bit compared to when I got it.
Reactions: johnno
In2Photos
2,574
2,775
Looks good for the most part, a couple of notes.
Consider buying a single 2TB drive instead. Cost is almost the same as 2 separate drives, but you get 500GB more storage. Also, the 970 is a Gen 3 drive, but the CPU and motherboard support Gen 4. Speeds are double for Gen 4. Real world use probably won't show too much difference but it's there.
The case you selected only has 2 fans included. I would add a couple more or look for a case that already includes more fans. I really like the Lian Li 216 that I used on my daughter's build. It came with 2 160mm up front and 1-140 in the rear. Tons of airflow. It also has 2 USB 3 Type A ports on the front instead of one like the Corsair.
Reactions: johnno
johnno
172
Thanks, will update drives, and look at the case.
I was planning on windows on the 500gb and games on the 1tb...do people still keep them apart? Also, already have a couple of 1tb SSDs.
nightspydk
339
19
Had that cpu cooler on an old build and it not a bad cooler but you can find something better even cheaper like the one in my sig.
Also of note if you havent tried mounting it before its a hazzle to remove the 212 evo imo
In2Photos
2,574
2,775
I too like to keep them separate. I did 500GB for Windows, but used 2TB drives for Gaming and Photos. When I built mine earlier this year the 4TB drives were much more than 2-2TB and I wanted at least 2TB each for Games and Photos so I picked up the 500GB just for Windows. You could use a partition on the bigger drive to keep them "separate". I didn't realize you already had some 1TB drives. Are they 2.5" SSD or NVME? 970 Evo Plus or something else?
Reactions: johnno
In2Photos
2,574
2,775
Also, what games you play? And what resolution? That will help choosing the video card.
Reactions: johnno
Dec 10, 2005
28,895
14,168
Consider the Peerless Assassin from Thermalrite as an alternative air cooler. It's usually pretty cheap, gets great reviews for cooling and noise, and is a bit more modern than that CM design.
Not sure what prices are like in the UK, but consider the 7800 XT for GPUs as well, especially if you don't use ray tracing.
I don't recall the details for the Corsair P5, but one thing to watch for on the OS NVME drive: try to go for a TLC-based drive with dram cache. It will help with drives with more frequent writing. QLC is generally fine for drives that are just data storage or don't have large write tasks all the time.
I have the 750W version of the PSU on your list, and the same case. I've been very happy with the combination.
Reactions: Shmee and johnno
nOOky
3,272
2,355
IMHO a 500GB drive is too small even for an OS drive these days. I'd use a 1TB minimum and a 2TB for storage. I'd go with the Peerless Assassin myself also. Otherwise not too much to nitpick it looks good. Windows 11 keys can be had for $20 American off of Kinguin or some similar site saving you a few bucks.
johnno
172
Thanks for the input, really appreciate your time.
As for a monitor, that will be next on the list!!
In2Photos
2,574
2,775
How much space is your OS taking up? Even my work laptop that has WAY more programs than my gaming PC and stores ~100GB of Drop Box files and email at any given time and it still has 200GB of a 500GB drive free.
manly
13,316
4,091
Agreed, a single 2TB drive makes better sense IMO.
I'd add that Nvidia is supposed to release refreshed graphics cards in less than 6 weeks. If that's true, I wouldn't buy a 4070 before then.
For the OS license, I bought mine recently (but have yet to use it):
Reactions: johnno
In2Photos
2,574
2,775
Happy New year all!
that time is approaching 😲 I have made a few changes...unfortunately it has got a bit expensive...and will still need a new monitor.
Looks good. You could possibly save money on the motherboard. Are there specific specs about the X670E that you need? MSI has a B650 version of the Tomahawk board that is £100 cheaper. You'll lose an M.2 slot, a PCI slot and an internal USB 3 header, but most builds probably don't need those. The X670 board loses a couple of USB type A ports but adds a second USB type C port on the back panel.
johnno
172
No specific specs, other than comment above, about X670e being higher end, that made me switch from the gigabyte b650 aorus elite ax.
In2Photos
2,574
2,775
My daughter has that Gigabyte board, it's been fine in her build with a 7600X for over a year now. A few quirks early on, but nothing major. I have an MSI B650 board in my build. Also been fine. Unless you find a great deal on the X670 board I see no reason to pay £100 more for nothing of great value.
Reactions: johnno
manly
13,316
4,091
I also think B650 is fine, but he also gets PCIe 5.0. The premium platform might make sense if he wants to upgrade CPU and NVMe in a few years?
Looks like everything on the list except for the RAM kit got more expensive after holiday sales? :mad: Oh and the refreshed GPU is a better deal than its predecessor. :rolleyes:
Reactions: johnno
BoomerD
66,332
14,746
Congrats. In 2019, I went from an i5-760/GTX660 rig from 2011...just before your 2500K was released...to an i7-9700K/RTX2070...WOW! Then, a year ago, I built a rig with an i5-13600K and RTX3070...Holy Cow! What a difference! (and I still had the i5-760 rig set up for a back-up to the i7-9700K, so I could actually compare that one with the i5-13600K)
Reactions: johnno and Pohemi
Pohemi
10,888
16,975
I was going to suggest the newer...
Thermalright Phantom Spirit 120 EVO​
...over the peerless assassin, but if you already ordered it, it's a little late for that. I know the peerless is a good cooler as well, so you shouldn't have any issues.
That Phantom Spirit EVO is around $40, and has better performance than Noctua's top of the line $120 cooler. It's impressive for the money.
Have fun with the assembly and setup...I always enjoyed that part of new builds.
Reactions: johnno
