I have a memory problem, please help.
LineMan
Hello all,
I installed a new 64mb dimm module (8Mx64 SDRAM)in my computer and on boot-up it recognised only 16mb. I began to look up different sites for help and on Intel's site there was a small piece about the 430VX chipset, which I have. It said the 430VX does not support x4 SDRAM configuration. It said it does support x8 and x16 SDRAM.
What does this mean and how would I know when I have the correct SDRAM?
I would appreciate any help, thanks.
AC
616
The 430VX is an old chipset for the original Pentium.
Since you have DIMMs, you most likely using a newer chipset. Go download DocMemory @ www.simmtester.com. It checks your RAM for problems. If it isn't bad RAM, I don't know what is wrong.
You can also try updating your motherboard's BIOS. But that may not be the cause of the problem.
TheNeck
431
if you could get the numbers off one of the chipsets on the module. from that info i could tell you what configuration your memory that you just got is.
LineMan
JobLessOne,
I cant get any numbers because I sent it back to Crucial.
The numbers on the box were CT8M64S4D10 and 8megx64.
Thanks for your help.
