I have a Gigabyte GA7 VRXP F12 motherboard and I need upgrade advice for digital camera graphics.
Seneca2
I have 256 name DDR 133 memory, I will get another stick of the same for 512 totals, is this enough? I can upgrade the video card if need be, but I can find next to no information on 2D performance, games are of small importance to me. What I have seen tells me that ATI 9200 -9600 with 256 memory is more than I need, is this correct?
I have a 1 gig Athlon running rock solid at 1.1 gigs, would a faster Athlon be worth the cost? I have a solid copper sink and a 3 speed fan and it keeps what I have now in the 40c range. My Antec case/w 4 Antec case fans helps.
jm0ris0n
1,407
Hi Seneca2,
Any graphics card with 64MB or more of videoram should be fine. Any ATI card sold in stores today will work great for editing/working with digital images.
2D Digital Imaging is not very videocard intensive at all. However you will notice the biggest performance increase with a faster processor.
If your motherboard can take a faster speed processor, this would be the best way to go. (I wanted to type more, but I have to go now).
mechBgon
Oct 31, 1999
30,699
For image editing, more memory will often help too. I've used over 750MB of RAM in PhotoImpact 6 at times. Another aspect of having lots of RAM is that Windows2000/WindowsXP will cache your image-editing program in RAM if it has enough RAM, so that it can re-launch from RAM instead of re-launching from the hard drive. Considering how slow PhotoImpact launches even from a 15000rpm SCSI drive, this is nice :)
tiap
572
It all depends on the size of the images are you are playing with. If its only a few mb then no big deal. I have used 125mb files and the more ram the better.
One machine I still use has an original aiw radeon with 32mb, on a tyan mb /w a p4 2.4 400fsb with 1 gig pc133 ram. I can do virtually any 2d imaging including dvd encoding etc with no lost frames. To shave a second or two from an image render is no big deal. two hundred renders a day doesn't amount to much. Video encoding was cut by 2 hours using a 2.8 prescott with 1gig 3500 ram etc. But I usually leave that overnite so 2 hrs saved doesn't matter either. It's all relative.
Go for a lot of ram and maybe a faster cpu. If money is no object get the latest and greatest.
