I hate power supplies
Nov 29, 2004
156
My aspire power supply is starting to die on me. Whenever I'm in a game or the PC is working double time the computer will usually turn off within 15 mins. I then need to turn the power supply off then turn it back on to get the system to boot.
So, I' ve decided I'm not go cheap anymore. From reading various threads on this board I'm leaning toward buying a seasonic. The price is reasonable and the quality according to people here is very good. Should I consider any other PSUs or should I go ahead and buy this Seasonic PSU
BigCoolJesus
Banned
Jun 22, 2005
1,687
Nope, stick with the Seasonic.
About the best PSU you can get in terms of reliability, stability and quietness (besides a PCP&C)
:thumbsup:
daniel1113
6,448
PC P&C > *
I wish they had a modular version of the 510 SLI, though. Man I love that PS.
t3h l337 n3wb
2,698
Seasonic is the bext for quietness and coolness, but you can get a cheaper Fortron/Sparkle and get the same, if not better performance, albeit with lower efficiency.
Allio
1,904
28
Or, forget all this overly expensive crap and just get a cheap and reliable Forton, Seasonic, Enermax or Antec, which will do everything you require.
I swear to god some of you people would recommend a Ferrari to your grandmothers.
t3h l337 n3wb
2,698
Yeah, amen to that.
imported_Owl
99
E-wiz has the Seasonic 500 for $110 delivered. I got in on this deal and love my 500. Very quiet and volt lines are rock solid steady. Great product. Also have and like PCP&Cooling Silencer 470.
CraigRT
31,440
Yeah, amen to that.
Yeah it's all good and true and all, but he is in search for the holy grail Ferrari, not a Toyota Camry. :p
That said, PCP&C rocks, but I'd go with a Fortron, Sparkle, or Seasonic, or something of the like for your system. I have an OCZ Modstream and I know it's not the best power supply out there, but it's plenty good enough for anything, it works perfectly.. so as long as you are not using Aspire anymore, you should be ok.
