I got the fastest Tbird 1800 Mhz !! pls help
smukkel
62
Everthing works fine but my tbird boots as a Athlon 1791 Mhz (199 x 9)
Mobo : Chaintech 7 AJA with awardbios. wtf. is wrong here...
Any advise ?
Noriaki
13,640
is it suppose to be a 900? And 100x9 ?
The multiplier is based off the 100Mhz clock rate for the FSB not the DDR-effective speed...
andrey
Hey, my Athlon TBird also for some reason reports 2399MHz instead of 2400MHz as it suppose to be. What is up with that ?
Mem
21,476
13
I was thinking that as well 9x100,anyway does that board have jumpers check they are right I would be very ,very surprised if you are running 199x9 that would be a new record for FSB on a Athlon,anyway try updating the Bios,I presume it`s not overclocked but giving you that false CPU clock reading.
Whitedog
3,656
My T-Bird is 3 GHz... :p
I have mine cooled with Liquid Helium.. hehe 1200 watt P/S
*sniff* *sniff* "What's that smoke I smell?"
Jonny
1,574
my tbird is 200 mhz!!
everyone overclocks..but I like being different, so I underclocked :)
hehe
jsbush
3,871
Look at my sig:
Edit: AMD Duron 600 @ 2000 (DDR) I'll take it out of my signature I odn't want people to think I'm an idiot hehe!
Jonny
1,574
wizkid, HTF did you get your threda above mine?? I posted before you....apperently time has changed directions!! :Q :Q :Q :Q
Jonny
1,574
WTF! jsbush, how did you get in between my 2 threads?? lol, this is hularious...my 2 threads were right in a row :)
pidge
Banned
Oct 10, 1999
1,519
I only got to 1791MHz to but then I switched out my 300watt power supply and replaced it with my 900watt power supply and everything is working fine now. You should see how fast the cards move after I win a game of solitaire. Man is it fast :D
Mem
21,476
13
Also try resetting the CMOS ,see if that brings the CPU reading back to the normal.
NOX
4,077
<< Hey, my Athlon TBird also for some reason reports 2399MHz instead of 2400MHz as it suppose to be. What is up with that ? >>
LOL...
HellRaven
659
Hey guys, check this out:
My Abit KT7 + Duron @ 2.6ghz (1)
My Abit KT7 + Duron @ 2.6ghz (2)
BTW, these are not edited pics - Actual desktop .bmp screenshots converted to .jpg
That was a real fun bug. I couldn't reproduce it at all it only happened once. It wasn't just a bug in the programs I used either. I checked motherboard monitor and the two cpuid programs in the screenshots and they all said I was running at 2.6ghz when I was only supposed to be at 1ghz. My guess is a bug in the via monitoring chip for whatever reason.
Viperoni
11,084
Hey guys, quit makin fun of the biggest weed distributor this side of the mississippi ;) :Q :D
Lol just joking there bud, although you gotta get your numbers straight :)
