I got question about rechargeable batteries...
RESmonkey
4,818
I just got some energizer e^2 rechar. batts. Do I use them right away, or do I recharge first?
I read the manual, nothing says anything about it.
LeetViet
2,411
Unless they are NiCD, there is no memory effect and you should be fine with using them right away.
dpert1
380
put them in whatever u bought them for, see if it works, profit?
if not, recharge em.
Aluvus
2,913
Consumer NiCd batteries do not exhibit any memory effect in any practical application. Neither do any other consumer batteries. Ever. And even if they did, it would have absolutely nothing to do with the OP's question.
@OP: Yes you need to charge them before use.
compman25
3,767
What do you consider practical applications? RC cars aren't exotic, and NiCd's for them do develop a memory.
Xstatic1
8,982
50
86
i actually called the company after i bought my charger + batteries...the rep i spoke with told me before 1st use, charge them twice.
0roo0roo
64,795
84
it honestly doesn't matter. if they arne't precharged/hybrid/enloop then u charge before use. if you didn't, your batteries are probably almost dead anyways so you'd have to charge them anyways. i use a durracel 15 min charger that gets rid of the hassle
BoomerD
65,943
14,338
I have a set of 4 Energizer NiMh AA batteries that I use for one of my digital cameras. I got them out a couple of days ago after not using them for about 4 months, and every one of them appears to have gone to battery heaven...NONE of them will charge...:(
maxster
Banned
Sep 19, 2007
628
AFAIK it isn't the memory effect but overcharging that decreases the life of your NiCD batts.
