I fscking HATE WIFI!
DaiShan
9,617
Originally posted by: CVSiN
Originally posted by: Pepsi90919
there is no such thing as an "ethernet cable".
wtf are you talking about...
n00b..
Ethernet is a protocol, it has nothing to do with cables. Generally Category 5 cables are used to carry ethernet packets on 100-base T networks, but they are certainly not the only option for transporting ethernet packets...
Pepsi90919
Originally posted by: DaiShan
Originally posted by: Goosemaster
Originally posted by: OdiN
My wifi is fast enough for games. It's faster than a cable connection is anyway.
It's not the bandwidth that matters, it's the latency and the reliability...
No problems in those areas either.
it's completely dependant of your confguration and your physical envirmoment and conditions...
oh, and try running a high-use fileerver on wireless with multiple clients;)
LOL why would someone think that is a good idea?
apparently odin might because he says that wireless is faster than wired.
DaiShan
9,617
'Cause WiFi going 15 feet introduces soo much latency and all. :roll:
Wifi period introduces so much latency period.
*Sigh* please leave the networking to the professionals. If you are in the Central FLorida area, I'd be happy to set you up an appointment with one of my tech's to come out and do a site asessment for WiFi and set it up properly
/edit also WiFi. Introduces so much latency. are two sentence fragments. I believe what you were trying to say is: WiFi introduces so much latency.
tweakmm
18,436
4
WiFi rocks.
If your reasons for hating WiFi revolve around how you don't want your roomate to use it so he'll get better ping times, you need to work on your arguments.
tweakmm
18,436
4
Where did he say this?
imported_goku
7,613
WiFi introduces tons of latency, it's unreliable and susceptible to interference. I don't live in florida and I know how to configure wifi.
Look, if WiFi is so great then why is it that you can't run a file server on it?
DaiShan
9,617
Look, if wifi is so great then why is it that you can't run a file server on it?
It is a half duplex connection, sending large files over half duplex will take forever, it has nothing to do with latency. This is the same reason why you don't run a file server over your cable internet connection, it is half duplex, it can either send or receive, not both. You will have no noticeable increase in latency from using wifi, unless you are doing something wrong/ you have really crappy equipment.
D
Deleted member 4644
Ever WiFi router I have ever had drops the connection every few hours. This is annoying enough for me that I stick to wired.
Pepsi90919
uh, you quoted it.
Injury
13,066
I played CS 1.6 on a wireless network that accessed the internet by bridging a dial-up connection to a non-wireless hub which in turn was connected to a wireless adapter.
I had a steady ping around 100 and I learned to deal with it.
The only difference a ping above roughtly 150ms makes is if your dumb ass runs straight into gun fire going for the spray and pray approach while rushing someone.
Other than that, you just have to learn that headshots require the slightest bit more leading of your shots.
Ping excuses are for people who can't deal with losing... also known as "whiners" or "sore losers".
imported_goku
7,613
Shens, never heard of a ping of 100 on dialup. My best ping I've ever gotten was IIRC 150 but overall was 200 ping on dialup..
tweakmm
18,436
4
uh, you quoted it.
Uh, are you refering to the cable connection comment?
imported_goku
7,613
uh, you quoted it.
Uh, are you refering to the cable comment?
Uh, Nested quoting?
tweakmm
18,436
4
uh, you quoted it.
Uh, Nested quoting?
Just making sure that I'm not missing something because it is painfully obvious to me that he's refering to a cable internet connection and assuming we are not talking about 802.11a, or some theoretical max cable speed his statement about his wirelss network being faster than his internet connection is quite correct.
Fraggable
2,799
uh, you quoted it.
Uh, Nested quoting?
Not that it matters, but the Pre-N routers theoretically get up to 108Mbps, just higher than the average 100Mbps wired LANs. Not that you'd ever get 108Mbps on wireless, but I just thought I'd throw it out there.
igowerf
7,697
My roommates and I used to play CS:S on pub servers through our one wi-fi router. We were all using wireless. With four people connected, we would get about 40-60ms pings on good days. There were tons of other wireless networks in our complex too. I could probably pick up about 10 from my desk and if I moved out into the living room, I could pick up a couple others.
thomsbrain
18,148
say hello to dead connections and crashed routers! :) hell, even bittorrent can be enough to bring down a wireless connection sometimes.
