I found the cause of my sound problems...you're not going to believe this!
Muerto
1,937
The problem is SETI@home. When I have it running I get horrid static and clipping when I play games, mp3s, or any other sound file.
But when I turn it off I get perfect sound. WTF?!?!? Anybody know why this might be happening? Thanks. :)
TheBigZ
629
Well, it DOES beat up on the cpu pretty hard. Could that have something to do with it?
Muerto
1,937
I don't think that's the problem. I had SETI going 24-7 on my K6-3 400 and SB AWE64. All the other components, except for the mobo, were the same as listed below.
tboo
7,626
Try enabling the memory hole at 15-16M option in you BIOS-that usually solves the static problem with VIA boards and the SBlive.
Muerto
1,937
I've already tried re-installing the drivers with no luck. I'll try enabling the memory hole in the BIOS at 15-16M.
And I'm already doing RC5 for Anandtech as well!!! :)
