I flashed my netgear rt314 router with 114 firmware, if i use console cable can i reset my router?
CoolTech
2,345
CoolTech
2,345
will this work for me?
Cables
the 6foot, im thinking about, since this router only came with a piece of cat5 :(
jmcoreymv
Once you get your serial cable, connect it to the router and to your pc. Load up hyperterminal (or a similar program) and set it to the com port of your serial port. Then boot up the router, itll tell you when to press a key so you can get in and reupload the new firmware via xmodem. Your going to have to look up the specific commands like 'at go' and 'atur1'.
