Zenmervolt
Elite member
- Oct 22, 2000
- 24,512
- 21
- 81
i drove it again yesterday and it seemed ok so im just going to forget about it for now unless something happens
This is a great idea.
ZV
yes it still works but you have to pull up on it more. i probably drove with it on before. i didnt see the dash cuz i use that space to hold a cup, flashlight, bridge fare etc... it was sort of blocked
I've never seen a car with rear disc brakes have a completely different brake for the e-brake. The ones I've seen just have a mechanical linkage to the e-break, so it's the same brake but activated/powered differently.
that's what i was going to say.
Tell-tales are installed right under speedmeter/tachometer/odograph just in front of you, so I try to believe you don't put anything there...yes it still works but you have to pull up on it more. i probably drove with it on before. i didnt see the dash cuz i use that space to hold a cup, flashlight, bridge fare etc... it was sort of blocked
I rented a John Deere 310 and trailer one time. When it was time to return it I parked in a steep part of my yard to hose down the hoe and the trailer so I set my e-brake. It was a fairly steep climb out of the property and I got about 3 miles down the road when I noticed my e-brake was still on. The 7.5 PSD hadn't missed a beat. I only noticed when I came to a stop sign and the truck coasted to a stop rather quickly.
No damage done.
This is wrong as a blanket statement.
Many companies use mechanisms for the parking brake that cause it to actuate the caliper for the rear disc brakes. Ford and GM both prefer such systems on cars with rear disc brakes. These cars have no separate parking brake.
While some cars with rear discs do have a small drum brake for the parking brake, this is typically only when the vehicle uses fixed calipers instead of the more common single-piston floating caliper designs.
In the case of the OP's Passat, the parking brake uses the normal service brake. If he drove for 20 miles with the parking brake on, his rear brake pads are likely quite nicely toasted.
ZV
Both my previous (2001) and current (2004) F150s have separate cable-actuated systems for the parking brake. Of course, these are both older vehicles, and trucks, and so are not representative of modern ones.
In most Ford cars (and some trucks), Ford uses a cable system that turns what is essentially a screw in the rear caliper, which presses on the piston and applies the service brake.
That system seems... overly complex and prone to failure.
Pretty simple, actually. The screw provides extra force as worm mechanism does a good job of transferring large motion-little force into small motion-lot of force.
I remember that first time too. Pretty neat demonstration of the facts.Fun fact: If you can feel the brake pedal go soft, when you pull the lever, that means you only have one brake system
First time I felt it, it weirded me a bit out. Not even sure which car that was.
ZV
They're called idiot lights for a reason.![]()
