I finally built my PC. I would like to thank the people here who help me do this. Without the help in these forums i dont think i would have managed. I think my pc would probably be fried! In the end i changed my case, the new one has a fan at the front and back and damm do they make noise!
Anyway, one or two more questions!
1) When i boot up the PC and go to the BIOS, the CPU temp goes up to about 43 degrees C. However if i boot into Windows ME or 2000 and run Abit's Program it says 30C for the temp CPU. If i then restart and go into the bios its at 30C?
Whats up with that? Is the temps i mentioned ok? by the way my system temp on both is 23C.
2) i have Windows ME on C and Windows 2000 on D partition. Both see each others drives as windows 2000 partition is FAT32. is keeping it FAT 32 ok, or should i go NTFS?
When I install a program in 2000 it likes to use the C:\program files directory (windows ME). How do i stop it and make it use d:\Program files?
Thanks So much!
Thanks So much!
