rocadelpunk
This is our first homework on the stuff and I dunno if I'm really missing something (probably) or I'm on right track..
problem 1
so i guess first thing was using demorgan's, then expanded it.
I dunno if the idenity x bar times x bar follows the same as x*x=x, but that's what I assumed and then since you have the two identical terms you can get rid of one of them, so final answer would be Abar*Bbar?
problem 2
so, i guess I'm just confused about how to simplify the (AB + Abar)
I tried to use the identity X + Xbar= (x + xbar)(x+y)= x+y...maybe it's b/c i woke up too early/too dumb 😛/too hungry
but i'm just stuck :/
problem 3
I hope what I did is correct...other than further factoring and doign A(C+D)+D on inside...i don't know what else I can do
problem 4
On this one I'm not quite sure what to do with the right side (it goes back to problem two where I'm not sure how to handle the xy+xbarz
Any help would be greatly appreciated. Thanks.
edit; i'm gonna go to my t.a.'s office hours for a few and then come back in case someone has a question for me.
problem 1
problem 2
problem 3
problem 4
