It works fine. (Note: I just built the tower from some old parts of mine, she had her own monitor and stuff) I tested it at my house and all was well. Then I took it over to her house, and plugged it up. When I turned it her monitor went nuts with crazy colors. Kinda like the res was set too high, but it was still just the post screen. Finally after....well....hitting the side of the monitor it began to work. But went crazy again when it hit windows. So I rebooted in safe mode, and it worked. While I was in there I made sure that everything was set as low as possible (640x480 in 16 colors) and rebooted. It booted up fine in normal mode. But I couldn't get it out of those low settings. So after figuring that it was just a really old monitor and was broke, I called it a night.
Yesterday she got a newer monitor from a friend. Its showing the post screen, but going blank in windows. I told her over the phone how to get it in safe mode, and that worked. I thought it was just some screwy settings and told her to set it at 800x600x16. And the same thing happened, viewable post screen, blank Windows screen.
She said the monitor she has now is a black Dell. Since it was black I thought it had to be relitively new. Possible they are two bad monitors in a row??
Heres a thought: Her house is pretty old. The computer and monitor are plugged into a power strip which is plugged into the wall ofcourse. But the Ground Prong is broke off of the powerstrip cord. Even if it had one, the wall plug doesn't have a hole for a ground plug. Does it really need to be grounded?? I didn't think that would matter, but who knows.
Specs:
Athlon 700mhz
Gigabyte MB
GeForce4 MX440
80gb WesternD HD (new)
CD ROM
Sound card and the lot.
I have a good monitor in my floor (its the one I used to set the system up in the first place) Should I try it?
Specs:
Athlon 700mhz
Gigabyte MB
GeForce4 MX440
CD ROM
