I broke the handle on my car door.
Status
Not open for further replies.
SunnyD
Belgian Waffler
Jan 2, 2001
32,675
www.neftastic.com
2007 Kia Sedona, sliding door. Cold morning, not frozen, just gets a bit stuck to the seals. I pulled a little too hard and pop, the handle broke. FML moment.
Not too expensive from what I can see to get a replacement - about $35 shipped. Only problem is they come unfinished, so I'd still have to take it to a body shop to have it matched and painted. I assume that will end up costing a small fortune regardless.
Yes, there's always the "scour the junk yards and see if I can find a matching one", but it will probably cost me more in gas just to track one down.
*ugh* It's been one of those days.
Baked
36,052
17
This is why you buy either a black car, or a black car, because all the replacement car parts come in black.
WilliamM2
3,011
892
For a door handle? Just get some matching spray paint from the dealer, or even dupli-color from the parts store, and some clear coat.
Gillbot
28,830
17
car-part.com and send out a request with the color code. They'll find one and often will ship to you for a great price.
phucheneh
7,306
I haven't ever seen dealers with spray paint, just the touchup pens/brushes. But you can order factory paint codes in a rattle can online.
Those handles are typically pretty simple to replace. Without a window regulator to get in the way, that one should be pretty easy. Sometimes the hardest part is just popping off the little plastic piece beside the actual handle without breaking it. Also be careful when disconnecting any control rods; they're usually held in place by little plastic clips that are easy to break.
Doppel
13,306
I did this on a vehicle a few years back. You can get one like you say and have it painted, or you can get OEM color match for over $100 or you can do what I did which is use an online car parts database that has junk yards in it. I found a part in the middle of nowhere easily with whatever site I ended up using and had it shipped, was in great shape.
PottedMeat
12,363
475
once you fix the handle spray some silicone lubricant on a rag and wipe it on the sliding door gasket
Status
