I broke my iTunes... very strange problem
Trevelyan
4,077
For some reason the left side of iTunes has disappeared for me. I tried reinstalling iTunes and I can't get it to come back.
Here's a pic of what I'm talking about: itunes.jpg
I tried finding the edge of it to drag it back, but I swear I can't do it.
Trevelyan
4,077
Originally posted by: n0cmonkey
Did you try stretching iTunes out? (click and drag lower left hand corner out)
Yep, tried that.
PLUS, look what happens when I try to make a playlist from the + button:
Trevelyan
4,077
Still nothing.. man this is driving me crazy. I uninstalled, cleaned the registry, and reinstalled and the same problem.
Trevelyan
4,077
I wonder, where does Windows store all the information about the last position/size of the window that was open? Like if you open IE after closing it at a certain size, it will relaunch in that same position.
Trevelyan
4,077
Ok, figured it out.
I just deleted the folder for Apple Computer\ITunes in the "Application Data" folder in documents and settings. That reset the view/preferences.
