I am ready to quit, please help me figure out how to configure X
pitupepito2000
Hi,
I installed debian at school, but I am having problems setting up X. It looks like the mouse is causing me problems. The mouse that I use is an intellimouse ps/2 3 buttons. When I choose dev/psaux on the setup I tried the options and it doesn't work.
please help me,
pitupepito
THere's a fix for that......you getting the crazy mouse?
I got a forum post somewhere.....I'll try to find it.
This is what my mouse config looks like...
Section "InputDevice"
Identifier "teh mouse"
Driver "mouse"
Option "CorePointer"
Option "Device" "/dev/psaux"
Option "Protocol" "ImPS/2"
Option "Emulate3Buttons" "true"
Option "ZAxisMapping" "4 5"
EndSection
Make sure the Mouse section in XF86Config-4 looks like this:
Identifier "Configured Mouse"
Driver "mouse"
Option "Protocol" "IMPS/2"
Option "Buttons" "3"
EndSection
Here's my XF86Config file:
### BEGIN DEBCONF SECTION
# XF86Config-4 (XFree86 server configuration file) generated by dexconf, the
# Debian X Configuration tool, using values from the debconf database.
# Edit this file with caution, and see the XF86Config-4 manual page.
# (Type "man XF86Config-4" at the shell prompt.)
# If you want your changes to this file preserved by dexconf, only make changes
# before the "### BEGIN DEBCONF SECTION" line above, and/or after the
# "### END DEBCONF SECTION" line below.
# To change things within the debconf section, run the command:
# dpkg-reconfigure xserver-xfree86
# as root. Also see "How do I add custom sections to a dexconf-generated
# XF86Config or XF86Config-4 file?" in /usr/share/doc/xfree86-common/FAQ.gz.
Section "Files"
FontPath "unix/:7100" # local font server
# if the local font server has problems, we can fall back on these
FontPath "/usr/lib/X11/fonts/misc"
FontPath "/usr/lib/X11/fonts/cyrillic"
FontPath "/usr/lib/X11/fonts/100dpi/:unscaled"
FontPath "/usr/lib/X11/fonts/75dpi/:unscaled"
FontPath "/usr/lib/X11/fonts/Type1"
FontPath "/usr/lib/X11/fonts/Speedo"
FontPath "/usr/lib/X11/fonts/100dpi"
FontPath "/usr/lib/X11/fonts/75dpi"
EndSection
Section "Module"
Load "GLcore"
Load "bitmap"
Load "dbe"
Load "ddc"
Load "dri"
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "pex5"
Load "record"
Load "speedo"
Load "type1"
Load "vbe"
Load "xie"
EndSection
Identifier "Generic Keyboard"
Driver "keyboard"
Option "CoreKeyboard"
Option "XkbRules" "xfree86"
Option "XkbModel" "pc104"
Option "XkbLayout" "us"
EndSection
Driver "mouse"
Option "Protocol" "PS/2"
EndSection
Identifier "Generic Mouse"
Driver "mouse"
Option "SendCoreEvents" "true"
Option "Device" "/dev/input/mice"
EndSection
Section "Device"
Identifier "ati"
Driver "ati"
VideoRam 8000
Option "UseFBDev" "true"
EndSection
Section "Monitor"
Identifier "Generic Monitor"
HorizSync 30-54
VertRefresh 50-85
Option "DPMS"
EndSection
Section "Screen"
Identifier "Default Screen"
Device "ati"
Monitor "Generic Monitor"
DefaultDepth 16
SubSection "Display"
Depth 1
Modes "800x600" "640x480"
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
EndSection
Section "ServerLayout"
Identifier "Default Layout"
Screen "Default Screen"
InputDevice "Generic Keyboard"
InputDevice "Configured Mouse"
InputDevice "Generic Mouse"
EndSection
Section "DRI"
Mode 0666
EndSection
Remove :
Driver "mouse"
EndSection
And
If that still doesn't work post your /var/log/XFree86.0.log
Delete everything you see here:
Driver "mouse"
EndSection
from what you just posted.
The config above that is what I used in the post I referenced above to get my crazy mouse to go away (using slack).
You can also remove the ZAxisMapping as that's just for scroll wheels.... (at least until you get the mouse back)
[edit]
damn got beat to the punch
Section "Files"
EndSection
Section "Module"
Load "GLcore"
Load "bitmap"
Load "dbe"
Load "ddc"
Load "dri"
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "pex5"
Load "record"
Load "speedo"
Load "type1"
Load "vbe"
Load "xie"
EndSection
Driver "keyboard"
EndSection
Driver "mouse"
EndSection
Section "Device"
Identifier "ati"
Driver "ati"
VideoRam 8000
EndSection
Section "Monitor"
HorizSync 30-54
VertRefresh 50-85
Option "DPMS"
EndSection
Section "Screen"
Device "ati"
DefaultDepth 16
Depth 1
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
EndSection
EndSection
Section "DRI"
Mode 0666
EndSection
Here's my log file for the XF86Config file
This is a pre-release version of XFree86, and is not supported in any
way. Bugs may be reported to XFree86@XFree86.Org and patches submitted
to fixes@XFree86.Org. Before reporting bugs in pre-release versions,
please check the latest version in the XFree86 CVS repository
(http://www.XFree86.Org/cvs)
XFree86 Version 4.1.0.1 / X Window System
(protocol Version 11, revision 0, vendor release 6510)
Release Date: 21 December 2001
If the server is older than 6-12 months, or if your card is
newer than the above date, look for a newer version before
reporting problems. (See http://www.XFree86.Org/FAQ)
Build Operating System: Linux 2.4.17 i686 [ELF]
Module Loader present
(==) Log file: "/var/log/XFree86.0.log", Time: Fri Apr 11 08:29:17 2003
(==) Using config file: "/etc/X11/XF86Config-4"
Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) ServerLayout "Default Layout"
(**) |-->Screen "Default Screen" (0)
(**) | |-->Monitor "Generic Monitor"
(**) | |-->Device "ati"
(**) |-->Input Device "Configured Mouse"
(EE) No core keyboard device specified
(EE) Unable to determine the screen layout
(EE) Error from xf86HandleConfigFile()
Fatal server error:
no screens found
When reporting a problem related to a server crash, please send
the full server output, not just the last messages.
This can be found in the log file "/var/log/XFree86.0.log".
Please report problems to submit@bugs.debian.org.
I changed it back and it didn't work here is the log file:
(==) Log file: "/var/log/XFree86.0.log", Time: Fri Apr 11 08:40:19 2003
(**) |-->Input Device "Generic Keyboard"
(**) Option "XkbRules" "xfree86"
(**) XKB: rules: "xfree86"
(**) Option "XkbModel" "pc104"
(**) XKB: model: "pc104"
(**) Option "XkbLayout" "us"
(**) XKB: layout: "us"
(==) Keyboard: CustomKeycode disabled
(WW) The directory "/usr/lib/X11/fonts/misc" does not exist.
Entry deleted from font path.
(WW) The directory "/usr/lib/X11/fonts/cyrillic" does not exist.
(WW) The directory "/usr/lib/X11/fonts/100dpi/" does not exist.
(WW) The directory "/usr/lib/X11/fonts/75dpi/" does not exist.
(WW) The directory "/usr/lib/X11/fonts/Type1" does not exist.
(WW) The directory "/usr/lib/X11/fonts/Speedo" does not exist.
(WW) The directory "/usr/lib/X11/fonts/100dpi" does not exist.
(WW) The directory "/usr/lib/X11/fonts/75dpi" does not exist.
(**) FontPath set to "unix/:7100"
(==) RgbPath set to "/usr/X11R6/lib/X11/rgb"
(==) ModulePath set to "/usr/X11R6/lib/modules"
(--) using VT number 7
(WW) Cannot open APM
(II) Module ABI versions:
XFree86 ANSI C Emulation: 0.1
XFree86 Video Driver: 0.4
XFree86 XInput driver : 0.2
XFree86 Server Extension : 0.1
XFree86 Font Renderer : 0.2
(II) Loader running on linux
(II) LoadModule: "bitmap"
(II) Loading /usr/X11R6/lib/modules/fonts/libbitmap.a
(II) Module bitmap: vendor="The XFree86 Project"
compiled for 4.1.0.1, module version = 1.0.0
Module class: XFree86 Font Renderer
ABI class: XFree86 Font Renderer, version 0.2
(II) Loading font Bitmap
(II) LoadModule: "pcidata"
(II) Loading /usr/X11R6/lib/modules/libpcidata.a
(II) Module pcidata: vendor="The XFree86 Project"
compiled for 4.1.0.1, module version = 0.1.0
ABI class: XFree86 Video Driver, version 0.4
(II) PCI: Probing config type using method 1
(II) PCI: Config type is 1
(II) PCI: stages = 0x03, oldVal1 = 0x8000880c, mode1Res1 = 0x80000000
(II) PCI: PCI scan (all values are in hex)
(II) PCI: 00:00:0: chip 8086,7190 card 0000,0000 rev 03 class 06,00,00 hdr 00
(II) PCI: 00:01:0: chip 8086,7191 card 0000,0000 rev 03 class 06,04,00 hdr 01
(II) PCI: 00:07:0: chip 8086,7110 card 0000,0000 rev 02 class 06,01,00 hdr 80
(II) PCI: 00:07:1: chip 8086,7111 card 0000,0000 rev 01 class 01,01,80 hdr 00
(II) PCI: 00:07:2: chip 8086,7112 card 0000,0000 rev 01 class 0c,03,00 hdr 00
(II) PCI: 00:07:3: chip 8086,7113 card 0000,0000 rev 02 class 06,80,00 hdr 00
(II) PCI: 00:0f:0: chip 1011,0024 card 0000,0000 rev 03 class 06,04,00 hdr 01
(II) PCI: 00:11:0: chip 10b7,9055 card 1028,0082 rev 24 class 02,00,00 hdr 00
(II) PCI: 01:00:0: chip 1002,4742 card 1028,4082 rev 5c class 03,00,00 hdr 00
(II) PCI: End of PCI scan
(II) LoadModule: "scanpci"
(II) Loading /usr/X11R6/lib/modules/libscanpci.a
(II) Module scanpci: vendor="The XFree86 Project"
(II) UnloadModule: "scanpci"
(II) Unloading /usr/X11R6/lib/modules/libscanpci.a
(II) Host-to-PCI bridge:
(II) PCI-to-ISA bridge:
(II) PCI-to-PCI bridge:
(II) Bus 0: bridge is at (0:0:0), (-1,0,0), BCTRL: 0x08 (VGA_EN is set)
(II) Bus 0 I/O range:
[0] -1 0 0x00000000 - 0x0000ffff (0x10000) IX
(II) Bus 0 non-prefetchable memory range:
[0] -1 0 0x00000000 - 0xffffffff (0x0) MX
(II) Bus 0 prefetchable memory range:
(II) Bus 1: bridge is at (0:1:0), (0,1,1), BCTRL: 0x88 (VGA_EN is set)
(II) Bus 1 I/O range:
[0] -1 0 0x0000e000 - 0x0000efff (0x1000) IX
(II) Bus 1 non-prefetchable memory range:
[0] -1 0 0xfc000000 - 0xfeffffff (0x3000000) MX
(II) Bus 1 prefetchable memory range:
[0] -1 0 0xf9000000 - 0xf9ffffff (0x1000000) MX
(II) Bus -1: bridge is at (0:7:0), (0,-1,0), BCTRL: 0x08 (VGA_EN is set)
(II) Bus -1 I/O range:
(II) Bus -1 non-prefetchable memory range:
(II) Bus -1 prefetchable memory range:
(II) Bus 2: bridge is at (0:15:0), (0,2,2), BCTRL: 0x02 (VGA_EN is cleared)
(II) Bus 2 I/O range:
(II) Bus 2 non-prefetchable memory range:
(II) Bus 2 prefetchable memory range:
(--) PCI:*(1:0:0) ATI Mach64 GB rev 92, Mem @ 0xfd000000/24, 0xfcfff000/12, I/O @ 0xec00/8
(II) Addressable bus resource ranges are
[1] -1 0 0x00000000 - 0x0000ffff (0x10000) IX
(II) OS-reported resource ranges:
[0] -1 0 0xffe00000 - 0xffffffff (0x200000) MX(B)
[1] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MXE(B)
[2] -1 0 0x000f0000 - 0x000fffff (0x10000) MX
[3] -1 0 0x000c0000 - 0x000effff (0x30000) MX
[4] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX
[5] -1 0 0x0000ffff - 0x0000ffff (0x1) IX
[6] -1 0 0x00000000 - 0x000000ff (0x100) IX
(II) Active PCI resource ranges:
[0] -1 0 0xff000000 - 0xff00007f (0x80) MX
[1] -1 0 0xf4000000 - 0xf7ffffff (0x4000000) MX
[2] -1 0 0xfcfff000 - 0xfcffffff (0x1000) MX(B)
[3] -1 0 0xfd000000 - 0xfdffffff (0x1000000) MX(B)
[4] -1 0 0x0000dc00 - 0x0000dc7f (0x80) IX
[5] -1 0 0x0000dce0 - 0x0000dcff (0x20) IX
[6] -1 0 0x0000ffa0 - 0x0000ffaf (0x10) IX
[7] -1 0 0x0000ec00 - 0x0000ecff (0x100) IX(B)
(II) Active PCI resource ranges after removing overlaps:
(II) OS-reported resource ranges after removing overlaps with PCI:
(II) All system resource ranges:
[5] -1 0 0xff000000 - 0xff00007f (0x80) MX
[6] -1 0 0xf4000000 - 0xf7ffffff (0x4000000) MX
[7] -1 0 0xfcfff000 - 0xfcffffff (0x1000) MX(B)
[8] -1 0 0xfd000000 - 0xfdffffff (0x1000000) MX(B)
[9] -1 0 0x0000ffff - 0x0000ffff (0x1) IX
[10] -1 0 0x00000000 - 0x000000ff (0x100) IX
[11] -1 0 0x0000dc00 - 0x0000dc7f (0x80) IX
[12] -1 0 0x0000dce0 - 0x0000dcff (0x20) IX
[13] -1 0 0x0000ffa0 - 0x0000ffaf (0x10) IX
[14] -1 0 0x0000ec00 - 0x0000ecff (0x100) IX(B)
(II) LoadModule: "GLcore"
(II) Loading /usr/X11R6/lib/modules/extensions/libGLcore.a
(II) Module GLcore: vendor="The XFree86 Project"
ABI class: XFree86 Server Extension, version 0.1
(II) Reloading /usr/X11R6/lib/modules/fonts/libbitmap.a
(II) LoadModule: "dbe"
(II) Loading /usr/X11R6/lib/modules/extensions/libdbe.a
(II) Module dbe: vendor="The XFree86 Project"
Module class: XFree86 Server Extension
(II) Loading extension DOUBLE-BUFFER
(II) LoadModule: "ddc"
(II) Loading /usr/X11R6/lib/modules/libddc.a
(II) Module ddc: vendor="The XFree86 Project"
(II) LoadModule: "dri"
(II) Loading /usr/X11R6/lib/modules/extensions/libdri.a
(II) Module dri: vendor="The XFree86 Project"
(II) Loading sub module "drm"
(II) LoadModule: "drm"
(II) Loading /usr/X11R6/lib/modules/linux/libdrm.a
(II) Module drm: vendor="The XFree86 Project"
(II) Loading extension XFree86-DRI
(II) LoadModule: "extmod"
(II) Loading /usr/X11R6/lib/modules/extensions/libextmod.a
(II) Module extmod: vendor="The XFree86 Project"
(II) Loading extension SHAPE
(II) Loading extension MIT-SUNDRY-NONSTANDARD
(II) Loading extension BIG-REQUESTS
(II) Loading extension SYNC
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XC-MISC
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-Misc
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension FontCache
(II) Loading extension TOG-CUP
(II) Loading extension Extended-Visual-Information
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) LoadModule: "freetype"
(II) Loading /usr/X11R6/lib/modules/fonts/libfreetype.a
(II) Module freetype: vendor="The XFree86 Project"
compiled for 4.1.0.1, module version = 1.1.9
(II) Loading font FreeType
(II) LoadModule: "glx"
(II) Loading /usr/X11R6/lib/modules/extensions/libglx.a
(II) Module glx: vendor="The XFree86 Project"
(II) Loading sub module "GLcore"
(II) Reloading /usr/X11R6/lib/modules/extensions/libGLcore.a
(II) Loading extension GLX
(II) LoadModule: "int10"
(II) Loading /usr/X11R6/lib/modules/linux/libint10.a
(II) Module int10: vendor="The XFree86 Project"
(II) LoadModule: "pex5"
(II) Loading /usr/X11R6/lib/modules/extensions/libpex5.a
(II) Module pex5: vendor="The XFree86 Project"
(II) Loading extension X3D-PEX
(II) LoadModule: "record"
(II) Loading /usr/X11R6/lib/modules/extensions/librecord.a
(II) Module record: vendor="The XFree86 Project"
compiled for 4.1.0.1, module version = 1.13.0
(II) Loading extension RECORD
(II) LoadModule: "speedo"
(II) Loading /usr/X11R6/lib/modules/fonts/libspeedo.a
(II) Module speedo: vendor="The XFree86 Project"
(II) Loading font Speedo
(II) LoadModule: "type1"
(II) Loading /usr/X11R6/lib/modules/fonts/libtype1.a
(II) Module type1: vendor="The XFree86 Project"
(II) Loading font Type1
(II) Loading font CID
(II) LoadModule: "vbe"
(II) Loading /usr/X11R6/lib/modules/libvbe.a
(II) Module vbe: vendor="The XFree86 Project"
(II) LoadModule: "xie"
(II) Loading /usr/X11R6/lib/modules/extensions/libxie.a
(II) Module xie: vendor="The XFree86 Project"
(II) Loading extension XIE
(II) LoadModule: "ati"
(II) Loading /usr/X11R6/lib/modules/drivers/ati_drv.o
(II) Module ati: vendor="The XFree86 Project"
compiled for 4.1.0.1, module version = 6.3.6
Module class: XFree86 Video Driver
(II) LoadModule: "mouse"
(II) Loading /usr/X11R6/lib/modules/input/mouse_drv.o
(II) Module mouse: vendor="The XFree86 Project"
Module class: XFree86 XInput Driver
ABI class: XFree86 XInput driver, version 0.2
(II) ATI: ATI driver (version 6.3.6) for chipsets: ati, ativga
(II) R128: Driver for ATI Rage 128 chipsets: ATI Rage 128 RE (PCI),
ATI Rage 128 RF (AGP), ATI Rage 128 RG (AGP), ATI Rage 128 RK (PCI),
ATI Rage 128 RL (AGP), ATI Rage 128 Pro PD (PCI),
ATI Rage 128 Pro PF (AGP), ATI Rage 128 Pro PP (PCI),
ATI Rage 128 Pro PR (PCI), ATI Rage 128 Mobility LE (PCI),
ATI Rage 128 Mobility LF (AGP), ATI Rage 128 Mobility MF (AGP),
ATI Rage 128 Mobility ML (AGP)
(II) RADEON: Driver for ATI Radeon chipsets: ATI Radeon QD (AGP),
ATI Radeon QE (AGP), ATI Radeon QF (AGP), ATI Radeon QG (AGP),
ATI Radeon VE (AGP)
(II) Primary Device is: PCI 01:00:0
(II) ATI: Candidate "Device" section "ati".
(II) ATI: Shared PCI/AGP Mach64 in slot 1:0:0 detected.
(II) ATI: Shared PCI/AGP Mach64 in slot 1:0:0 assigned to active "Device" section "ati".
(II) resource ranges after xf86ClaimFixedResources() call:
(II) Loading sub module "atimisc"
(II) LoadModule: "atimisc"
(II) Loading /usr/X11R6/lib/modules/drivers/atimisc_drv.o
(II) Module atimisc: vendor="The XFree86 Project"
(II) resource ranges after probing:
[9] 0 0 0x000a0000 - 0x000affff (0x10000) MS
[10] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS
[11] 0 0 0x000b8000 - 0x000bffff (0x8000) MS
[12] -1 0 0x0000ffff - 0x0000ffff (0x1) IX
[13] -1 0 0x00000000 - 0x000000ff (0x100) IX
[14] -1 0 0x0000dc00 - 0x0000dc7f (0x80) IX
[15] -1 0 0x0000dce0 - 0x0000dcff (0x20) IX
[16] -1 0 0x0000ffa0 - 0x0000ffaf (0x10) IX
[17] -1 0 0x0000ec00 - 0x0000ecff (0x100) IX(B)
[18] 0 0 0x000003b0 - 0x000003bb (0xc) IS
[19] 0 0 0x000003c0 - 0x000003df (0x20) IS
(II) Setting vga for screen 0.
(==) ATI(0): Chipset: "ati".
(**) ATI(0): Depth 16, (--) framebuffer bpp 16
(II) Loading sub module "int10"
(II) Reloading /usr/X11R6/lib/modules/linux/libint10.a
(II) ATI(0): Primary V_BIOS segment is: 0xc000
(II) Loading sub module "ddc"
(II) Reloading /usr/X11R6/lib/modules/libddc.a
(II) Loading sub module "vbe"
(II) Reloading /usr/X11R6/lib/modules/libvbe.a
(II) ATI(0): VESA BIOS detected
(II) ATI(0): VESA VBE Version 2.0
(II) ATI(0): VESA VBE Total Mem: 8192 kB
(II) ATI(0): VESA VBE OEM: ATI MACH64
(II) ATI(0): VESA VBE OEM Software Rev: 1.0
(II) ATI(0): VESA VBE OEM Vendor: ATI Technologies Inc.
(II) ATI(0): VESA VBE OEM Product: MACH64GT
(II) ATI(0): VESA VBE OEM Product Rev: 01.00
(II) ATI(0): VESA VBE DDC supported
(II) ATI(0): VESA VBE DDC Level none
(II) ATI(0): VESA VBE DDC transfer in appr. 2 sec.
(II) ATI(0): VESA VBE DDC read failed
(--) ATI(0): ATI 3D Rage Pro graphics controller detected.
(--) ATI(0): Chip type 4742 "GB", version 4, foundry UMC, class 0, revision 0x01.
(--) ATI(0): AGP bus interface detected; block I/O base is 0xEC00.
(--) ATI(0): ATI Mach64 adapter detected.
(--) ATI(0): Internal RAMDAC (subtype 1) detected.
(==) ATI(0): RGB weight 565
(==) ATI(0): Default visual is TrueColor
(==) ATI(0): Using gamma correction (1.0, 1.0, 1.0)
(II) ATI(0): Using Mach64 accelerator CRTC.
(II) ATI(0): Storing hardware cursor image at 0xFD7FFC00.
(II) ATI(0): Using 8 MB linear aperture at 0xFD000000.
(!!) ATI(0): Virtual resolutions will be limited to 8191 kB
due to linear aperture size and/or placement of hardware cursor image area.
(II) ATI(0): Using Block 0 MMIO aperture at 0xFCFFF400.
(II) ATI(0): Using Block 1 MMIO aperture at 0xFCFFF000.
(==) ATI(0): Write-combining range (0xfd000000,0x800000)
(II) ATI(0): MMIO write caching enabled.
(--) ATI(0): 8192 kB of SGRAM (1:1) detected (using 8191 kB).
(WW) ATI(0): Cannot shadow an accelerated frame buffer.
(--) ATI(0): Internal programmable clock generator detected.
(--) ATI(0): Reference clock 157.5/11 (14.318) MHz.
(II) ATI(0): Generic Monitor: Using hsync range of 30.00-54.00 kHz
(II) ATI(0): Generic Monitor: Using vrefresh range of 50.00-85.00 Hz
(II) ATI(0): Maximum clock: 230.00 MHz
(II) ATI(0): Not using default mode "1024x768" (vrefresh out of range)
(II) ATI(0): Not using default mode "1024x768" (hsync out of range)
(II) ATI(0): Not using default mode "1152x864" (hsync out of range)
(II) ATI(0): Not using default mode "1280x960" (hsync out of range)
(II) ATI(0): Not using default mode "1280x1024" (hsync out of range)
(II) ATI(0): Not using default mode "1600x1200" (hsync out of range)
(II) ATI(0): Not using default mode "1792x1344" (hsync out of range)
(II) ATI(0): Not using default mode "1792x1344" (bad mode clock/interlace/doublescan)
(II) ATI(0): Not using default mode "1856x1392" (hsync out of range)
(II) ATI(0): Not using default mode "1856x1392" (bad mode clock/interlace/doublescan)
(II) ATI(0): Not using default mode "1920x1440" (bad mode clock/interlace/doublescan)
(II) ATI(0): Not using default mode "1400x1050" (hsync out of range)
(--) ATI(0): Virtual size is 800x600 (pitch 800)
(**) ATI(0): Default mode "800x600": 56.3 MHz, 53.7 kHz, 85.1 Hz
(II) ATI(0): Modeline "800x600" 56.30 800 832 896 1048 600 601 604 631 +hsync +vsync
(**) ATI(0): Default mode "640x480": 36.0 MHz, 43.3 kHz, 85.0 Hz
(II) ATI(0): Modeline "640x480" 36.00 640 696 752 832 480 481 484 509 -hsync -vsync
(++) ATI(0): DPI set to (100, 100)
(II) Loading sub module "xaa"
(II) LoadModule: "xaa"
(II) Loading /usr/X11R6/lib/modules/libxaa.a
(II) Module xaa: vendor="The XFree86 Project"
(II) Loading sub module "ramdac"
(II) LoadModule: "ramdac"
(II) Loading /usr/X11R6/lib/modules/libramdac.a
(II) Module ramdac: vendor="The XFree86 Project"
(II) Loading sub module "fb"
(II) LoadModule: "fb"
(II) Loading /usr/X11R6/lib/modules/libfb.a
(II) Module fb: vendor="The XFree86 Project"
ABI class: XFree86 ANSI C Emulation, version 0.1
(II) do I need RAC? No, I don't.
(II) resource ranges after preInit:
[0] 0 0 0xfcfff000 - 0xfcffffff (0x1000) MS
[1] 0 0 0xfd000000 - 0xfdffffff (0x1000000) MS
[2] -1 0 0xffe00000 - 0xffffffff (0x200000) MX(B)
[3] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MXE(B)
[4] -1 0 0x000f0000 - 0x000fffff (0x10000) MX
[5] -1 0 0x000c0000 - 0x000effff (0x30000) MX
[6] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX
[7] -1 0 0xff000000 - 0xff00007f (0x80) MX
[8] -1 0 0xf4000000 - 0xf7ffffff (0x4000000) MX
[9] -1 0 0xfcfff000 - 0xfcffffff (0x1000) MX(B)
[10] -1 0 0xfd000000 - 0xfdffffff (0x1000000) MX(B)
[11] 0 0 0x000a0000 - 0x000affff (0x10000) MS(OprU)
[12] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS(OprU)
[13] 0 0 0x000b8000 - 0x000bffff (0x8000) MS(OprU)
[14] 0 0 0x0000ec00 - 0x0000ecff (0x100) IS
[15] -1 0 0x0000ffff - 0x0000ffff (0x1) IX
[16] -1 0 0x00000000 - 0x000000ff (0x100) IX
[17] -1 0 0x0000dc00 - 0x0000dc7f (0x80) IX
[18] -1 0 0x0000dce0 - 0x0000dcff (0x20) IX
[19] -1 0 0x0000ffa0 - 0x0000ffaf (0x10) IX
[20] -1 0 0x0000ec00 - 0x0000ecff (0x100) IX(B)
[21] 0 0 0x000003b0 - 0x000003bb (0xc) IS(OprU)
[22] 0 0 0x000003c0 - 0x000003df (0x20) IS(OprU)
(II) ATI(0): Using XFree86 Acceleration Architecture (XAA)
Screen to screen bit blits
Solid filled rectangles
8x8 mono pattern filled rectangles
Indirect CPU to Screen color expansion
Solid Lines
Offscreen Pixmaps
Setting up tile and stipple cache:
32 128x128 slots
22 256x256 slots
6 512x512 slots
(==) ATI(0): Backing store disabled
(==) ATI(0): Silken mouse enabled
(**) Option "dpms"
(**) ATI(0): DPMS enabled
(WW) ATI(0): Option "UseFBDev" is not used
(II) Initializing built-in extension MIT-SHM
(II) Initializing built-in extension XInputExtension
(II) Initializing built-in extension XTEST
(II) Initializing built-in extension XKEYBOARD
(II) Initializing built-in extension LBX
(II) Initializing built-in extension XC-APPGROUP
(II) Initializing built-in extension SECURITY
(II) Initializing built-in extension XINERAMA
(II) Initializing built-in extension XFree86-Bigfont
(II) Initializing built-in extension RENDER
PEXExtensionInit: Couldn't open default PEX font file Roman_M
(II) Keyboard "Generic Keyboard" handled by legacy driver
(**) Option "Protocol" "intellimouse"
(**) Configured Mouse: Protocol: "intellimouse"
(**) Option "CorePointer"
(**) Configured Mouse: Core Pointer
(**) Option "Device" "/dev/psaux"
(==) Configured Mouse: Buttons: 3
(**) Option "Emulate3Buttons" "true"
(**) Configured Mouse: Emulate3Buttons, Emulate3Timeout: 50
(**) Option "ZAxisMapping" "4 5"
(**) Configured Mouse: ZAxisMapping: buttons 4 and 5
(**) Option "BaudRate" "1200"
(**) Configured Mouse: BaudRate: 1200
(II) XINPUT: Adding extended input device "Configured Mouse" (type: MOUSE)
Could not init font path element unix/:7100, removing from list!
Fatal server error:
could not open default font 'fixed'
Here's the XF86Config file:
Section "Files"
EndSection
Section "Module"
Load "GLcore"
Load "bitmap"
Load "dbe"
Load "ddc"
Load "dri"
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "pex5"
Load "record"
Load "speedo"
Load "type1"
Load "vbe"
Load "xie"
EndSection
Driver "keyboard"
EndSection
Driver "mouse"
EndSection
Section "Device"
Identifier "ati"
Driver "ati"
VideoRam 8000
EndSection
Section "Monitor"
HorizSync 30-54
VertRefresh 50-85
Option "DPMS"
EndSection
Section "Screen"
Device "ati"
DefaultDepth 16
Depth 1
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
EndSection
EndSection
Section "DRI"
Mode 0666
EndSection
Is xfs running? 'ps axw | grep xfs'
Do any of the paths in the FontPath statements exist?
Also do you have defoma installed? That's the Debian font manager, it handles all of that for you.
Thanks for the help Nothinman. This computer that I am trying to get x working is a computer at school, and I will try to get it to check the process that you said on Monday when I go to school
Thanks again,
pitupepito
