Hi there
I have just succesfully after some problems, managed to give my whifes old ASUS P2B new life with my old PIII 600Mhz. That was done through the use of a slot1/socket370 converter.
I have set the converter up to use the default voltage which is 1.65V. But in my BIOS is says 2.05V. But I am not able to see the CPU temp. The CPU runs perfect, but for how long at 2.05V?. I have tryied to use ASUS probe without any luck. How do I read the CPU temp??. If its possible through a converter??
What next??? Which program??
Thanks.
Thanks.
