I am new to wireless routers.. bought a Dlink Gamerlounge, need help.
JiveCoolie
329
The signal is extremely low (20% - 30%)
I am in a different room then the router itself. Someone told me to take it back and get a Wireless-N instead of a Wireless-G (which is what the current router is)
Would that help? Thanks!
Tarrant64
3,203
The router may not be the culprit. What wireless device are you using to connect to the router? Built-in laptop card? USB adapter? PCI card?
I don't think wireless-n is a standard yet, and for just being in a different room I'm not so sure just switching the router out will solve the problem.
