I am installing my first door knob
JoeFahey
2,163
I bought a new doorknob to replace my old one. I took out my old one, and cleaned out the inside. Everything seems like it will go fine, except the round hole I need to cut through the door from front to back. It says I need to drill a 2-1/8" hole. The largest bit I have is ~1". Do they make spade bits that are 2-1/8"? What type of bit would you suggest for such a hole?
Also, the strike plate the goes on the wall for the door will need to have a larger carved out hole. I have a chisel. Is this the recommended tool for this job?
Thanks.
JoeFahey
2,163
Originally posted by: KLin
Are you talking actual drill bits or hole saws?
Whatever you should use to drill the 2-1/8" hole. I am now assuming that I use a hole saw.
speed01
1,167
Run down to the local hardware store and grab a doorknob installation kit. It should come with the spade bit for the bolt and the hole saw for the knob..
Speed
JoeFahey
2,163
Originally posted by: oldsmoboat
Good luck getting a hole saw started in the old hole.
Fortunately there is already a small 2-1/8" hole started. It must have been to embed the old knob or something.
speed01
1,167
Just thought of something, are you going to cut a new hole because the directions say to or because the new doorknob won't fit? I know this may be a dumb question but it wasn't specified if you already tried the new knob..
Speed
olds
50,124
778
You lucked out. The only other way I know to do it is to tack another piece of wood over the old hole and shoot for the center of the existing hole.
alkemyst
83,769
19
well a hole saw is a drill bit.
Harborfrieght will probably be your best bet for a one deal job. I bought a nice set (1"-3") at a lowes or home depot that was on clearance for being an open/returned item...saved about 75% off new.
If you do use a hole saw, make sure you use one with a center drill bit. They may not have instructions for this, but basically the center of the saw accomodates a 1/4" drill bit...there should be a set screw to secure it.
JoeFahey
2,163
Speed
The directions said so.
olds
50,124
778
So you're saying to use a drill bit with his drill bit?
speed01
1,167
Just for giggles, try the new one in the old hole. If it works, jobs done..
Speed
olds
50,124
778
As far as the striker plate:
Remove old striker
Center new striker over old
Trace with a sharp pencil
Cut out with a chisel
speed01
1,167
Remove old striker
If that's even needed also. Most doorknobs and strikers I've replaced fit just fine in the existing recesses and holes. No sense making more work than needed..However, if you do need to, ^^^ that's how.
Speed
olds
50,124
778
Remove old striker
Speed
I also use 3" drywall screws for the striker. Makes it harder to kick the door in when the screws are into the frame and not just the jamb.
KLin
30,429
746
Remove old striker
Speed
Now that's a good idea. I'm going to have to remember that. :thumbsup:
JoeFahey
2,163
Remove old striker
Speed
I don't think I am going to ask why you are afraid to have it kicked in...
0roo0roo
64,795
84
Remove old striker
Speed
well i bought a cheap door set once and its screws were definetly short, more expensive shlage model had a much sturdier strike plate/plastic thingie for reinforcing the hole and 3" screws included.
