Originally posted by: Squisher
I have to admit that it is either the weather we've seen the last couple of years or where I live now, but I get a ton of wind now. The wife was pushing me to build one of these until I said the HOA probably wouldn't go for it.
OP, nice job so far.
Originally posted by: Eli
lol.. How did I miss this thread?
What are you planning on using as a generator? Please say Ametek tape drive motor.
What about blades? Where did you get those?
How much wind do you honestly get? You will need to put that on your roof if you expect it to generate any meaningful power... It needs to be away from things that affect wind, like fences and bushes.
The generator mount is going to pivot, right?
http://www.tlgwindpower.com/ <--- good site for parts and info.
Aren't the 38V Ametek's aweful for generating power?
I'm so out of the loop, I don't have links handy.. but there is lots of info out there. The best Ametek motors for this type of application are the 40 or 50V ones, IIRC... The 99V Ametek is the ultimate, but it takes a bigger overall setup to get it turning.
I've got one of the 30V ones, which are fairly decent.. I think 0.225V/RPM?
When it comes to wind generators, the blades are everything. They're what really determine how much power you're going to be able to get. Some of the micro blades on TLG are fairly inexpensive, you might want to look into them.
Its been my plan for quite a while to build a portable wind generator for use at the beach. It will run the solar/wind powered cooler I built a while back.
That's generally the idea, yeah.Originally posted by: AlienCraft
Is the energy stored in battery banks? or what?
