Hyundai Imagequest L90D+ Monitor makes 'buzzing' sound?
MaDfLaMe37
153
It's really quite annoying. When I turn off the monitor the sound ceases. I don't think it's a vibration as when I move around the monitor/tap on the sides it still buzzes. I'm sure there's probably nothing I can do to stop it, but if by change anybody has a suggestion or at least an idea of what the problem is, I would appreciate your input!
FeuerFrei
9,144
929
Maybe a backlighting bulb is going bad? Just a wild guess. I have a L90D+ and it's never made any noise in 4 years.
iahk
707
my gateway monitor was doing the buzzing noises for a few months before it died :(
PM650
476
Could be related to an inverter or the smps going bad, although I have yet to come across a monitor with similar symptoms.
corkyg
Elite Member | Peripherals
27,370
239
After studying this review, the thought comes to mind that the buzzing could well be coming from the monitor's power supply. Apparently Hyundai uses an unconventional ciruitry in this area. If the buzzing is coming from the built in speakers, you might consider disconnecting them. Buzzing is often EMI related to A/C shielding.
L90D
Just a tought - if you can, you might try using the analog connection instead of the digital, and see if that makes any difference.
MaDfLaMe37
153
Corkyg - I believe you were somewhat right with the part about the speakers. I had the audio cable unplugged from the back of my PC and it was sitting on a metal heater unit behind my desk. When I took it off of that the buzzing stopped.
Meh... :/
corkyg
27,370
239
OK - you were mainlining EMI into the speakers. Good move.
