Question Hyper 212 RGB Black Edition RGB header extensions (Help)
EpicSurvivor
1,044
48
Hi I was wondering how long the RGB Header for the Hyper 212 RGB Black Edition is. I would like to have the RGB header cable to run behind the motherboard instead of through the inside of the case. Can anyone help?
Can't you buy RGB Header extensions? I did read online that you are not supposed to use the extension as first connection to the motherboard. Is there anything wrong with doing that? That's kinda what i wanted to do.
The motherboard will be a Gigabyte Aorus Pro by the way.
Thanks
aigomorla
21,052
3,533
it seems the RGB function is controlled by the controller it comes with.
It says its asrock polychrome compatible, but i have very little knowledge working with that.
I would assume there is a type of extension, however im fairly sure Coolermaster would provide you with a cable long enough to reach the said port for your asrock polychrome header.
EpicSurvivor
1,044
48
I didn't have time to update the thread but I was looking through my Z390 box and found an RGB header extension! so I am set to go.
