HWZone Forum - Sapphire R9 Fury X pics and benchmarks!
tolis626
399
Well, seeing as the underlying architecture is practically the same GCN we know (and love?) I wouldn't expect Fury GPUs to overclock well. Sure, HBM frees up die space etc etc, but I guess the stream processors and the transistor configuration is largely the same as Hawaii and Tonga. I don't think the cards will be TDP limited but rather limited by the silicon lottery. Also I don't think there's any point at overclocking the memory. It already sits at over 500GB/s of bandwidth. Not being able to tinker with it would be a bummer, sure, but not a deal-breaker by any stretch of the imagination.
With all that said, and with me usually drooling over well-overclocking chips, I don't really think that the high-clocking Maxwell GPUs will have such a big advantage over the Fury, simply because Maxwell GPUs rely a lot on their high clockspeed potential to be as fast as they are. Reference cards already boost at 1300+MHz, so a jump to 1400-1500MHz isn't THAT huge. Still bigger than a possible 100MHz for the Fury, but nothing that creates a chaotic difference.
I say we wait to see what results proper overclocking gives. I couldn't care less how it overclocks at stock voltage, be it AMD or NVidia GPUs. Max the thing out and then we can talk. :D
5150Joker
5,549
www.techinferno.com
Here's what I get with a Titan X in SoM:
1440p:
150% scaling (3840 x 2160):
Biggest question should be how far Fury X can overclock. If I can hit 1500 MHz on my air cooled reference Titan X's, then aftermarket 980 Ti's certainly should hit those speeds if not higher. If that's the case, Fury X is in trouble if it can't OC well. I did find Fury X's performance at 4K to be pretty close to the Titan X so it should be on par with the stock 980 Ti (but will certainly lose to the non-stock ones in this game). One interesting thing you will note is that the Titan X doesn't benefit much from higher clocks passed 1408 MHz in this game, could be a CPU limitation. If anyone ends up with a Fury X + 5820K I'd like to compare.
Edit: I just saw his overclocked results and they get close with avg fps to my 1408 MHz ones which is good news since he only had a 100 MHz OC (his max stable OC on stock voltage) BUT look at his min fps: http://i995.photobucket.com/albums/...Mordor 2015-06-24 01-09-27-54_zpsjor6x1j3.png 29.34 vs 45 fps (assuming his run was at 4k). His signature says he has a 4670K, does anyone know if SoM is CPU dependent for min fps? If the min. fps inconsistency isn't shown in official reviews, then AMD has a solid card on it's hands (at least at 4K) as long as it can keep up with Crossfire profiles and day 1 driver releases for AAA titles.
Face2Face
4,100
215
1440p:
Thanks for the comparison. Not sure about the minimum FPS anomaly?
gamervivek
490
53
The results for SoM look rather low, a 390X is like 10% behind a 980Ti in that game so Fury should be doing way better than that.
sam_816
432
Can it be driver problem? May be AMD will launch new drivers(review sites might already have them) with the launch of fury..
DiogoDX
747
279
Majcric
1,386
48
980ti SoM benchmark results @1440p, if anyone wants to see another comparsion .
Avg 88.58
Max 115.71
Min 54.33
