HWPlus dvd-decoder + Geforce2 Pro 64mb??
SilverThief
5,720
Just wondering if I should get a Hollywood Plus decoder card instead of using the GF2 Pro for dvd playback. Will the image quality be any better?
majewski9
2,060
yes! Gforce cards do not really have hardware decoding like ATI cards!
A hollywood plus would provide much lower cpu usage than just a Geforce2 card! I don't know if it would help image quality, but I think it wouldn't hurt.
Noriaki
13,640
Don't use the HWMC on a GF2....it worsens image quality.
But if you are in pure software mode, as long as your GF can provide decent 2D quality, the DVD playback quality should be about the same between a good software player and an H+.
Now if you are talking about playback on a TV, the GF has poor image quality on a TV. The H+ will be much better.
mdXtreme3d
627
yeah, the H+ is the best solution for PC dvd on TV (unless you have a progressive scan HDTV-ready set), but it's monitor output is only so-so.
Fenix793
1,439
Use the Hollywood for TV-Out its just like watchin on a set top player. As for watching movies on your PC, the only problem is it uses a pass thru cable so your normal 2D gets pretty blurry, however the quality is amazing. A lot of people say that software is just as good but I have to wonder if those people have ever seen a Hollywood baord at work. Its very good and much better than anything the gf2 can do. IMO it is def. worth the money and if you get the remote its even better.
BCYL
7,803
Hmm... reading some of you guys replies, a question comes to my mind...
I currently have the Hollywood+ card and a GeForce 2 GTS card... I love the DVD playback on this setup, however I also play some games... will my games improve (graphically) if I plug my monitor into my GeForce instead of going thru the Hollywood+?
Noriaki
13,640
Depends on the Resolution.
The Hollywood Plus can handle up to about 1024x768 without seriously hurting the monitor quality.
Past that it starts to degrade pretty badly. The board is capable of 1600x1200 but I would never want my monitor hooked up through my H+ at 16x12..
BCYL
7,803
Oh damn.... I am running my PC (& my games) at 1152x864 resolution... I guess I should turn it back down to 1024x768...
