Question HWinfo64 Chipset 2 (xHCI) sensor not detected on one system of the two with identical motherboard.
Dave3000
1,520
114
I have 2 systems with the same motherboard. On one of the systems, I noticed that the Chipset 2 (xHCI) sensor is not being detected by HWinfo64. From what I understand is that the X670E chipset is actually 2 X670 chipsets and should HWinfo64 show both Chipset 1 and Chipset 2? The motherboard is a MSI X670E Tomahawk. Also is there a way to verify that both X670 chipsets on that motherboard are working properly?
Well, if I turn on my USB printer then the Chipset 2 (xHCI) will be detected in HWInfo64. Also the other system had SATA SSDs installed and this one doesn't have any SATA drives installed.
