- Jun 13, 2000
- 26,392
- 1,780
- 126
How many vents should I put in a 600 square foot room on the 2nd floor of my house with a garage downstairs? It's going to be insulated pretty well all around. My floor joists are going to limit where I put vents...I know I can easily get 4 in...I'm just worried about more than that (mostly because of logistics of running the ducts through i-joists).
Originally, I was going to just do a mini-split for the 600 square feet + a bathroom and tie in a second room to my existing unit, but worry I won't get enough pressure 60 feet down the line to get the return air to work out. It also may not cool the stairwell/hallways effectively in the summer due to the increased heat in the attic deadspace... Also, for the cost, it makes more sense to do a 2-ton heat pump and make that wing of the house its own zone.
My existing living space is 1700 square feet one story.....and I'm adding about 1050 to it. (3 rooms)
