Husky air compressor with bonus air tool kit
Doggus
57
I'm not sure if this is a good deal or an average deal. I have seen a couple of contractors who posted here before so I'm hoping they'll chime in with their opinions
Husky 5 Peak HP 22 gallon air compressor 6.5 SCFM
Bonus air tool kit includes:
3/8" air ratchet
1/2" impact wrench w/ socket set
Air chisel with two bits
Spray gun
Tire chuck
Coupler
1 female and 5 male plugs
air hose, blow gun tire gauge
All this for $299, but wait there's more:
If you sign up for a Home Depot card you get 10% off. And you may even be able to combine this with their current 'Great tool trade-in' for another 10% off for a grand total of $240.
Anyone use this equipment from Husky? The salesman told me they had this same deal last year for a little while.
Just thought I would add that this was in our local circular and I could not find anything online to reference.
JJd
343
Decent price for a very serious tool. Once you get used to using air tools you never want to go back. Only catch is the compressor takes up valuable space. :) Go for it if you need one! :D
Evadman
Administrator Emeritus<br>Elite Member
Feb 18, 2001
30,990
Not a bad deal at all. This is from Home Depot.
The tools:
3/8" air ratchet ($25)
1/2" impact wrench w/ socket set ($40)
Air chisel with two bits {$19)
Spray gun ($25)
Tire chuck ($3)
Coupler ($2)
1 female and 5 male plugs ($10)
air hose, blow gun tire gauge ($25)
The tools are a nice add on, but not really worth it. For the average homeowner, yes it is handy. but you would be better off buying a $300 compressor and only getting the tools you need. The ones they provide for free are not the best. the air ratchet and impact w/tools go for $49 as a kit. The other stuff is little stuff, but it adds up.
I have used just about every compressor under the Sun, and I like Husky. Much better than Cambell Hausfield. That being said, I own a Ingersol Rand :)
And yes, the double 10% should work on this. Although it will only be 10% + 9% if you do the math :p
Doggus
57
And yes, the double 10% should work on this. Although it will only be 10% + 9% if you do the math :p[/quote]
oops...just like compounding interest only now were compounding discounts. Is there any way to do the math where it comes up free? ;)
Netma
169
Any good 2 HP compressor will deliver 6.5 SCFM. The HP ratings you see on compressors nowadays are rediculous. I assume this is a 120 volt unit. You can't run a true 5 HP motor on 120 volts, even if its a 20 amp receptacle. It would take at least a 20 amp 240 volt feed.
Princeman
487
I been looking for a house paint sprayer. Guess this would due but seems a lot for one. Maybe I'll wait a little more.
theshamu
476
Does anyone know how big a compressor (in terms of HP?) is necessary to blow out (winterize) an irrigation system in one's yard (assuming average size)? I pay to get it done, but have wondered if I can do this myself if I own an air compressor. :)
Doggus
57
Originally posted by: ULI
Is this a vertical or horizontal standing compressor?
It's vertical with 2 pnuematic tires. Stands about 3 1/2 feet high and I think it can be used horizontal as well.
Analog
12,755
is it a 2 stage?
jbserra
276
I tried to get the $277 Craftsman 150 PSI 30gal vertical air compressor w/6-HP max (#16731), but I didn't make it in by Sunday. It went back up to $329, but now they added an air tool pack for free. Rumor is, it will be on sale on Nov 2nd for $299 w/the air tools, and with the craftsman club, it will be $269 with the air tools. I was thinking of getting in on this. Any comments on this one? Sounds better then the Husky?
For those who are going to ask, Craftsman Club is just something you can sign up for at Sears. No cost. I found the application right by the checkout, and they send you special sales for club members only.
Racketear
290
I agree these companies play with the service factors on the motors to make it appear that you are getting something better, when infact you are getting a identical product. And you can run anything on 120v, but the amperage draw would be astronomical 40+ amps as opposed to 20 amps. Most 5 hp motors in the real world seem to draw about 25-30 amps. That is at a reasonable service factor.
Doggus
57
Sounds like a good deal. Our Sears has a compressor with a bonus tool pack but doesn't have the air chisel and the paint gun which is what I'm after. Maybe I'll buy the Home Depot deal and keep it in wraps till this Craftsman deal hits and compare them then.
NogginBoink
5,322
Is this an "oil-less" compressor?
Unless I'm mistaken, the "oil-less" compressors are so unbelievably loud that you won't want to turn it on very often. I'm convinced that it's worth the extra money to upgrade to a belt-driven (is that the correct distingusing feature) model when I buy a compressor.
The noise difference is like the difference between a jet airplane and the noise of pedaling a bicycle, from my experiences.
arcas
2,155
Like you implied, it depends on the size of your installation and more importantly, how big each zone is. The blowout pressure is fairly low but it requires a compressor that can deliver a very large volume of air or else you're going to be spending all day doing it. I don't think a portable consumer air compressor will produce enough SCFMs to winterize a typical irrigation system in a reasonable amount of time. The pros I've seen do this used a towed diesel-powered compressor similar to what you see powering jackhammers.
Now, that said, I routinely use a small compressor (60 gallon tank) to blow out the swimming pool lines though I could get by with an even smaller tank at the expense of taking longer. In this case, each "zone" consists of maybe 40 feet of 1.5-inch PVC and no more than 2 outlets. In an irrigation system, the pipe is likely smaller diameter but alot longer and there will probably be more than 2 sprinklers per zone. The more sprinklers you in the zone, the more SCFMs you'll need to dump into the pipe. If your irrigation system is small enough, you might be able to get away with it.
Dan2
203
Husky is a pretty good brand. Their wrenches and socket sets are on the same level as Craftsman (similar warranty, pricing, etc).
I bought this same set about 6 months ago (I was scared at first because I usually only buy Craftsman) to use on my cars and have loved the kit since. It was the best deal I could find and the quality is excellent. As mentioned the tank sits vertically and moves around pretty easily. It comes with everything you'll need, too, even teflon tape and hose.
Who cares how loud the compressor is? I mean, it's somewhat loud, but if you're using an impact wrench and ratchet anyway, the tools are still louder than the compressor. And once you've filled the tank it lasts quite a while before needing to fill again.
BTW, the tools separately at Home Depot are a lot more expensive. The impact and air ratched alone around $50-80 each I believe.
jbserra
276
Wow, I mention it in the morning, and my craftsman club catalog shows up in the afternoon.
Here it is:
Free air tools & accessories
$139 Value when you buy either of these craftsman 150PSI compressors
- 3/8 in impact wrench
- 3/8 in ratchet
25 ft hose/connectors
Horizontal or vertical tank
Craftsman 6-HP, 150-PSI max 30 gal vertical or 33-gal horizontal air compressor
Looks like single cylinder, oil-free.
$285 each
My price this morning was assuming the $299 sale price - 10%, but for some reason it is not a full 10% off for the craftsman club.
November 1 -> 7th
NOW, the tools sound much better with the husky, and it could potentially be $240, but it is 5 HP and 22gal. Worth the splurge for more HP and gallons with the Craftsman?
theshamu
476
Thanks, arcas! I had a feeling that the size of the tank is more important here. I suppose I could estimate the volume of air required for each zone and get an idea for the amount of air needed. But I can see this may require a monster size air tank, not sure it's a sound idea to do it for once-a-year use. :(
Evadman
Feb 18, 2001
30,990
Originally posted by: ULIis it a 2 stage?
What is 2-stage?
That means there are 2 pistons in the air compressor. The first feeds the second.
According to someone who should know, it depends on how many sprinkler heads you have. He said you should have 15 CFM @ 40 psi for each sprinkler head. He also said not to exceede 50 PSI if when blowing it out out.
Is this compressor enough to paint cars with an HVLP spray gun?
Yes. About 2x what you need. HVLP systems require 7-10 CFM @ 50 PSI or so, which this will do easy.
It is oil less AFAIK. And yes, they tend to be louder. but not quite that loud. maybe 30-40% louder than a non oil free.
T2T III
My brain hurts after reading this thread. Granted, I've gotten in on a lot of "Hot Deals" from this forum, but I don't think my wife would appreciate me buying this device so I could add air to our bike tires. :D :D :D
The Husky gear, in general, appears to be quite well made. I thought (now this is just a thought and it's 3:00 A.M. for me), but I recall reading an article in the past where the same tool supplier that was manufacturing the Craftsman tools was also making the Husky line. Again, this is just a recall of some old information that I may have heard about a year ago. But, I do own a Husky torque wrench - and it's nicely made. Additionally, you have Home Depot to back you up on your purchase. If, for some reason, you don't like the gear, just head back to HD with your receipt and get a refund. You wouldn't believe the gear that HD gets back - lawnmowers and weed whackers that have been used (and abused) for a season get frequently returned for refunds.
Evadman
Feb 18, 2001
30,990
They are not returned for refunds. They are exchanged for snowblowers. Happened every year at my store.
