Husky 275 ft/lb impact & 45 ft/lb air ratchet & tools for $39 @ Home Depot
Evadman
Administrator Emeritus<br>Elite Member
Feb 18, 2001
30,990
Friendly neighborhood Home Depot man here :)
HD is clearancing out an air impact kit. The kit is $39 and contains:
  • impact gun
    • Husky Model H4103
    • 275 ft/lb (box says 250, instructions 275)
    • 4 torque settings
    • 8000 rpm no load speed
    • 1/2" drive
    • 4 CFM
    • 1300 IPM
  • Air ratchet
    • Husky Model H4003
    • 45 ft/lb
    • 150 RPM
    • 3 CFM
    • 3/8" drive
  • Extras
    • 3/8" to 5/8" 5 piece sockets
    • 3/8" to 1/2" drive adapter (so sockets fit on ratchet)
    • 3" extension
  • other goodies
    • 2 male quick connect air fittings
    • 1 femake qucik connect air fitting
    • rubber tipped blow gun (nifty!)
    • blow molded case
not bad for $39. These can only be found at the B&M stores. The UPC is 722470016328. Enjoy.
Evadman
Feb 18, 2001
30,990
Originally posted by: Pliablemoose
I'm all over this, are you back @ HD or are you lurking around the store?
I'll take the 5th amandment for $500 Alex.
Delbert
1,306
Rushed to the nearest HD. No joy. Bummer. I'd try another across town but I think I will call first. Thanks though Evadman.
Better put in a whoot for post number 500. Whoot!
Evadman
Feb 18, 2001
30,990
the first post in this thread was my 14,500. only 14,000 to go :p
The store I got mine at had 2 more. Most stores will have a ton of these unless they were sold earlier, but if they are going on clearance, they didn't sell too well :p
rsolomon
395
Colorado Springs North (Woodmen) location had nothing, South Academy had 1 which is now in my trunk!
A couple of extra bits of info which may help when calling:
Model H2242 (was $59.97, now $39.00)
SKU 265-500
Yes, the H4103 gun alone is ~$60 on the shelf right next to this...
Thanks Evadman!!!!!!
altus22
33
Originally posted by: Howard
What exactly does an impact wrench do?
If you have to ask, don't waste your money.
It acts like a box end wrench with someone tapping (or beating) on the end with a hammer. This vibration and torque makes most nuts and bolts come out very easily. Great for automotive work.
All over this! Thanks.
bparks6982
7
Hmmm... isn't this about the time of the year that they run their 40% off yellow tag items? Or have they quit doing this?
Mir96TA
1,950
37
[*]blow molded case[/list][/list]
What is B&M store ?
Desslok
3,780
11
Originally posted by: Mir96TA
Originally posted by: Evadman Friendly neighborhood Home Depot man here :) [*]blow molded case[/list][/list] not bad for $39. These can only be found at the B&M stores. The UPC is 722470016328. Enjoy.
What is B&M store ?
Brick and Mortar
Evadman
Feb 18, 2001
30,990
Basicly it is an air powered ratchet. It runs on air from an air compressor. This gun applies the same about of torque as you jumping up and down on a wrench. Basicly, you cna change a tire in about 60 seconds by yourself, easy.
Those were basicly to clear the stores of clearance merchandise in a short amount of time so that new stuff could be moved in. AFAIK most of the clearance stuff went out the doors, but it is very possible it could be a yearly event now. Even being an employee, you did not know until the night before. If you know what you are looking for in a HD store you could probably tell. Hell, just ask an employee. If they know they will tell ya. Just don't ask someone who looks like a manager :p
Evadman
Feb 18, 2001
30,990
Originally posted by: huesmann
yeah, any deals on compressors?
SKU 692-181 -- 5.5 honda powered gas compressor. cool dual tank design by Ingersol Rand Contractor series. $235, down from $799. Superduper hot deal if you can find one! YMMV Though. I got one in my Garage :)
Small comressors, I got no idea. I tend to buy big things :p
halik
25,696
WHAT?
i think you got confused with a concrete drill or somethign,
last time i checked impact wrench was jsut a wrench powered by air
Childs
11,313
7
WHAT?
I believe the air creates a smacking or impact like effect to produce the torque, like an impact driver, when you smack it with a hammer to produce torque.
If anyone is in the Salinas area, there are 3 left.
Delbert
1,306
Originally posted by: Howard What exactly does an impact wrench do?
If you have to ask, don't waste your money. It acts like a box end wrench with someone tapping (or beating) on the end with a hammer. This vibration and torque makes most nuts and bolts come out very easily. Great for automotive work. All over this! Thanks.
WHAT? i think you got confused with a concrete drill or somethign, last time i checked impact wrench was jsut a wrench powered by air
I believe the air creates a smacking or impact like effect to produce the torque, like an impact driver, when you smack it with a hammer to produce torque. If anyone is in the Salinas area, there are 3 left.
yes, an impact wrench is different than an air ratchet. An air rachet is included in the kit however.
Edit. Dang. Had to edit every post today for typos. Mavis?
