Railgun
- Mar 27, 2010
- 1,289
- 2
- 81
Sure no problem just keep using it...:whiste:
I've been using it for 8 years.
Sure, they'll never look at the fuel when a possible fuel related failure occurs and they have a big warranty repair...
Sure, they'll never look for any excuse to blame it on the owner...
Of course not...
I don't know what I was thinking...
This is BS. Same people sit in their car for 30 mins with the engine running in the morning because they think it's "good to warm up the car" before driving. Wrong. They also top off their gas tanks. Bad idea.
Not if you don't tell them. How will they know, if the engine fails and they dealer has to replace it? It's not like there'd be anything inside to give it away, and that's ASSuming they even bother to tear it down in the first place. Most dealerships nowadays, if there's an internal engine issue, they just put another motor in it.
/drinks beer with bartmanNo way dood your no where near it...
But yea have to agree years back it was used quite often but with today's newer systems it would not be a wise choice... As for a catastrophic engine failure no way and do not want that impression given (if used in the fuel not the "crankcase" which is a different story)... While it might cause an issue with a Cat or and O2 sensor over time depending on the ratio it wont hurt much else but in that article it leads to the conclusion that it might just gunk up certain parts...?
I would just opt for a "good" fuel system cleaner and even consider the middle grade of fuel or better... But what do I know I drive a diesel...:twisted:
Its all good...:biggrin:
'Gasoline is too dry,' says this guy? (no, this isn't the beginning of a poem)
Perhaps gain some real-world experience before making these assumptions.
Oh noes! A fuel injector failed! QUICK, DRAIN ALL HIS FUEL AND SEND IT TO US FOR IN-DEPTH SCIENTIFIC ANALYSIS!
...or maybe just read my above post.
What's wrong with topping off your gas tank? Do you just fill yours half way?
