- Aug 12, 2001
- 40,730
- 670
- 126
First impression: it works fine.
Visual quality seems about the same as on the PS3, and I had no buffering or stalling problems. It's better than the earlier versions of the PS3 app (which did have problems) but the last PS3 version before The Great Outage fixed those for me.
The user interface is a bit less fancy than the PS3 one, and unless I missed an option you can't just browse the full list of choices the way you can on the PS3, you need to use Search instead. Search works well, as you pick each letter a-z the matching titles list narrows down.
Suggested show to watch, that isn't on Netflix: ReGenesis - biotech drama that's sort of a cross between House, X-Files and MI-5/Spooks.
