I've just built this system in the last couple days, and got around to installing vista 64 bit this morning. Here are my specs:
Intel Q9550
Gigabyte p45-ud3p
2x2 gb corsair cominator ddr2-1066
seagate 7200.11 1tb drive
antec 900
lg dvd burner
pc power and cooling 750w
bfg gtx 260 oc maxcore
windows vista 64 bit
So my problems began when installing vista. It kept freezing during the install, so I ended up disabling almost everything in the bios, unplugging everything that wasn't needed, and ran the memory at very low settings. I got it to complete, but I was noticing when playing around in windows that it was very sluggish, and I had to power off the computer several times when it would freeze complelely. I noticed my ram usage was at max a couple of times when i wasn't even doing anything. I had to reboot.
I just tried starting a game (necrovision), and i got a bsod. When the computer started up, it was trying to boot off the dvd instead of the hard drive for some reason. When i looked in the bios, my hard drive had disappeared! I loaded defaults and the hard drive reappeared.
I really need to get this figured out, any help would be appreciated. I ran memtest86+ 2.11 for 1.5 days with my rams current settings - ddr21066, cl 5-5-5-15 cmd 2, 2.1 volts, and no errors were found. No OC is currently on the processor.
Intel Q9550
Gigabyte p45-ud3p
antec 900
lg dvd burner
