Originally posted by: BigGreenMat
Could somebody do me a favor and go through the exact steps you go through to achieve these OC's? I just want to know the proper way to keep the configuration I put together.
Originally posted by: GuitarDaddy
I don't think memory is holding you back. I'm running my OCZ at 232mhz 2-3-3-5 with 2.8v. I think you need to up the CPU volts, 170mhz is most likely the best you will get on stock voltage. Change from the auto setting to 1.6375 (seems to give 1.50 - 1.52 actual) per CPUZ and AI booster. And also experiment with lower CPU multi and settings like 234 x 12 = 2808, you can take advantage of that fine OCZ ram.
You might even get 240 x 12 = 2880mhz with ram at 240mhz, that would be wicked fast. I get an extra 500-600 points in 35mark05 running ram 232 vs 200, with the same CPU mhz.
With the FX-55 chip your overclocking range is most likely not as great as with my 3200+, but with the unlocked multiplier's the ways to overclock that chip are almost limitless. jealous I amSo if you don't get the OC you want, try it a different way
288 x 10 = 2880mhz DDR333/ ram=240mhz
210 x 14 = 2940mhz ram=210
325 x 9 = 2925mhz DDR266(or AUTO) ram=217
273 x 11 = 3003mhz DDR333 ram=228 Dare we dream!!!
I'll quit now, my jealousy is increasing
Oh, and don't forget to drop that HTT multi to 4x if you use a setting higher than 220, and 3x over 260
Originally posted by: Insomniak
/Begin Hijack
While we're on the subject of overclocking, perhaps you gents could provide some input:
I've gotten my A8N-SLI Deluxe rig up and going, and now I'm fiddling with the OC. System follows:
ASUS A8N-SLI Deluxe (1002)
Athlon 64 3000+ Winchester (DH8-D0) (2196Mhz, 244FSB, 4xHTT, 1.5125v)
1GB Mushkin Basic Green PC3200 (~400Mhz, 2.5-3-3-8, 2.7v, 5:4 divider)
Now, all this checks out in windows...The system Primed for 8 hours last night with no errors, warnings. It swallowed 4 hours of Half-Life 2 without breaking a sweat. When I checked the temp this morning before stopping Prime, it was at 44C, so I'm assuming that's the highest load temp it's going to hit.
Weird thing is, sometimes it boots perfectly, and sometimes it gives me a system boot fail. I've fiddled with the RAM voltage, and that doesn't seem to be the issue, so now I'm edging up CPU voltage. I imagine it's one of these two culprits - one of them simply needs more juice - but any other ideas?
I'm also considering taking the RAM back to 1:1 and seeing how high I can ride it, but I'll have to check the net a bit and see what this stuff is supposed to hit before I try that - get a ballpark idea.
/End Hijack
