I bought a 900mhz Thunderbird and then i had to decide on an MB... I had a tough time picking between the Asus A7V and the Abit KT7... well I decided to save a few bucks and go for the Asus, 'cause I didn't have an immediate need for the RAID abilities, eventhough something inside me really pushed me to fo with the Abit board (great past expereinces with them).
Well I got the board plugged everything and powered up... well NOTHING happened. I was pissed... so I tried pulling everything outta' it trying to figure out what was causing the problem. Anyways, I still haven't found the problematic component, but I was able to get the unit to power up by pulling everything out execpt for the floppy, an Adaptec 3940UW scsi card (has a 4.3 gig segate baracuda sca80 version... with the sca80-68pin adapter attached... and a plextor ultraplex 40x wide) and the last thing connected is a the Annihilator 2 card.
anyways... I am able to get it to boot, but it's super unstable. I on occasion i see some garbled asci charcters on screen... and I need to power down and then back up to sort it out.
Most of the time the system freezes and I cant do anything.
After it does it's POST and junk I can't get it to boot off of the SCSI CDROM eventhough it detects a bootable CDROM (win2k pro). I've even tried to boot the system off a floppy but that doesn't work either... if it does start reading the floppy... the system will freeze.
I've never had this sorta problem before so any and all help will be greatly appreciated.
