Hey y'all. Just wondering if I could get a few quick explanations on the differences between hubs, routers, and switches.. technical differences and applications. I'm mostly looking to set up a LAN for purposes of surfing, gaming, transfers, etc. I've heard that routers are better than hubs because you can have multiple IP addresses.. so if I were to share DSL with other people in my apartment/house, that might be a better way to go. Also, is it safe to assume that I should only look for 10/100 Mbps unless I am only going to use the network for web surfing.. in that case, I could just go with a 10 Mbps? I think I'll probably be looking for a Linksys or Netgear since those two names seem to pop up quite a bit.. any other good brands out there for cheap?
Thanks for your input.
