Hub + Standard corporate networks...
Kelemvor
16,928
8
Howdy,
Just wondering if you think this would work or if I shouldn't even bother trying. In a standard corporate office with cubes where each cube has one network port for plugging in a PC... If we temporarily need an extra port in that cube, would you think it would work to simply plug a littlr 4 port hub into the port? Would that theoretically give me 4 ports in the cube or could there be a reason that wouldn't work? I've never tried it before but thought I'd ask before I go digging out an old hub I have around somewhere and bringing it with me.
The PCs all use standard DHCP etc so no Static IPs or anything like that.
Thanks.
gunrunnerjohn
1,360
It will normally work, though as suggested, I'd ask the IT folks. I've done that at multiple places without any issues...
mboy
3,309
If your IT dept ok's it (if you even have one), use a 4 port switch instead of a hub. A hub most likely will give u problems (it has for me in the past) but a switch (which is cheaper nowadays anyway) will work JUST fine.
gunrunnerjohn
1,360
I'm at a loss as to why a hub would be any more problematic than a switch. :confused: OTOH, I do agree that a switch is a better choice in any case, since as you say, costs are equal anymore...
mboy
3,309
Hub didn't work for me when I tried it (with a straight thru cable).
gunrunnerjohn
1,360
Well, if you connect a hub onto a connection intended for a computer NIC, you'd need to use the uplink port or a cross-over cable. I suspect the switch you happened to pick was auto-sensing so it didn't matter. I doubt it was the hub that was the issue, just the fact it didn't have the correct connections.
Kadarin
44,296
16
I've done it before as well. Check with your IT department; sometimes paranoid shops will enable MAC security on their switch ports to prevent unauthorized network access.
mboy
3,309
Switch the hub was connected to was auto sense.
p0lar
634
It is a better idea to use a switch, if it's permitted, but only if your environment is switched. If it isn't, and uses a hub (why?) then a hub may be a better choice.
When you connect a switch to a hub, it will only transfer packets at half-duplex. Keep your collision domains separated - excepting extreme circumstances, there isn't much place for a hub in any environment now-a-daze.
mboy
3,309
yup, only place I use a hub is for my web monitoring server and Snort sensor (between LAN and firewall) as I don't have any managed switches to port mirror on :-(
p0lar
634
mboy: precisely the application that would be acceptable in a low-budget environment. (=
