hub compatibility?
JCase
199
The lan I am on right now uses only OLD Boca 10 base hubs, which work fine, but seem to have issues when trying to link other brands to them. I attempted to hook up a linksys hub via the link port, and could not get a connection between the hubs. When using another Boca hub, though, it connected fine. My problem now is that the Boca hubs are very hard to find, and I need to link up another one to expand our lan. Any ideas on a compatible hub?
martind1
777
if they are just hubs, then you shoudl be able to mix and match with no problem. Your mistake must be in the cable/port combo you are choosing.
you connect a straight patch form the uplink to a port inn the higher up hub
hub1
hub2 hub3
hub2 and hub3 are connect in their uplink port to a non-uplink port in hub1.
