This company features some mini-keyboards with ir + Wireless.
http://www.riimini.com/
I guess you have to have some kind of IR receiver that plugs into usb or something like that. It is designed to work with TV's and other devices.
Veris EZ will do it pretty inexpensively. You can also program other remotes for it.
But how would you set it up to power ON/OFF your PC? It says its a USB device, that means when the computer is off the device is off as well since there's no power. I would assume you'd need something that connects to the motherboard..
most motherboards, BUT NOT ALL, support power on sleep over usb. its all up to the motherboard.
the windows media center remote kit has a power on function. it works just like any tv or dvd player. it will even turn on your pc from hibernation. again though, the motherboard has to support the function so that remotes and such can utilize it. the only catch is, of course, if your computer is fully shutdown then you must use the button on the case.
This is great so I can actually get away but just using sleep instead of shut down.
