- Nov 21, 2007
- 1,550
- 0
- 76
Hey guys, i just bought a X-Fi platinum that comes with the front panel, what type of cable should I run to my TV for sound? There are aux in's on the front panel, but not outputs so I don't think i can run the standard white and red cables from the panel to the TV
what kind of cable do you recommend to run from my PC to my TV (which only has standard white and red aux in's)
Please link the cable in your reply!
Thanks
Thanks
