Ive been trying to troubleshoot an issue im having with my htpc. its an older system using an MSI K8NGM2-FID motherboard, AMD 3700+ 939 processor and 3GBs ddr ram (2x 1gb/2x 512mb), and Seasonic 430W power supply all in a Zalman 160 htpc case.
the problem started after the system experienced a few shut downs in a row. the system would just shut off on its own. this happened a handful of times as i tried to troubleshoot the issue, but it now wont show any display when trying to boot.
I tried pulling all but one stick of ram( trying each of my 4 sticks individually) , switching out the power supply, and plugging in a video card (using the onboard up to this point), but none of that made any difference. The msi board has a button to reset the cmos, but that didnt change anything either.
my first thought was maybe the onbaord video had failed since the system was getting power (i.e. fans spin up, hdds spin up and stay running, etc). I got hold of another msi K8NGM2-FID board and big suprise, same issue. with the new board in place, i only kept the front panel power/reset switch connected to the board, nothing else except the cpu fan and of course the psu cable. i unplugged all other fans, usb, firewire, audio, etc. I even pulled the mobo battery and left it out for a day. it still does nothing but get power. the cpu fan spins up and stays running, but i get no display at all.
so at this point, either all of the ram i have is bad or the cpu is at fault. i just wish i could confirm that somehow before i go buying more parts. also, could my case be causing this type of issue? since it has a vfd display, i had it connected to the power for power and a usb connection. but ive tested with just the front panel power switch connected, so i dont know if its related.
any other suggestions going forward would be much appreciated
