HTPC case or case + accessories recommendation?
Pandamonium
1,628
I'm looking for an HTPC-style case with a built-in IR receiver. However, the IR receiver has to be wired such that it can turn a computer on from S3, S4, or S5 via a remote like the Microsoft MCE remote. I also want the case to use >= 80mm fans for ventilation, have only one 5.25" bay, accept standard ATX PSUs and full-height PCI/PCIe cards, and ideally, also be made of mostly aluminum. (Edit: I also am not a fan of LCDs on cases)
I've been searching high and low for such a case or combination of parts, but I'm not having very much luck. Does anyone have any ideas?
So far, I know that iMON equipped cases can power up from at least S3, but since I want to use a Logitech Harmony remote, I don't want to pay for the extra iMON remote/software. Does anyone have something like this set up?
DSF
4,902
If you haven't asked around in the Cases and Cooling forum that might be a better place. There are some people with pretty extensive knowledge of cases who don't peruse General Hardware much.
syee
827
Have you tried checking out the Antec Fusion line of cases? I can turn my PC on from S3 using my Logitech diNovo Mini keyboard using the receiver. I believe (but don't quote me on this since I've only ever used my MCE remote once) I could turn on my PC using the remote as well.
You said you don't like LCD's on cases - this one does have a display on the case, but I think one of their smaller ones doesn't. (although you may lose remote capability with it)
mrSHEiK124
11,488
Right. The Fusion cases without VFD/LCD don't have the built in IR receivers, IIRC.
I just built a new HTPC with the silver Fusion, came with 430W PSU, VFD, and a built in IR receiver. My MCE remote wakes it up from sleep, since it just parses keyboard presses to the LCD/IR receiver.
