thestrangebrew1
I already have a g630 cpu & windows 7. Just looking for hardware for the box atm, not too worried about peripherals. Is this possible given my budget of about $150? I did see a few things I might possibly pick up unless you guys recommend otherwise:
http://www.newegg.com/Product/Produc...82E16856119062
or go with this:
http://www.newegg.com/Product/Produc...82E16813135288
and find a better case. I'll also need to get RAM and if I choose the latter, I'll have to get a psu as well. I'm also debating on BD/DVD drive. Haven't decided if I'll need it. This build won't be used for storage and will be connected to my server, but we do use Red Box frequently (I use my ps3 to stream and watch Red Box rentals currently).
or go with this:
