Hi folks. I'm planning to build an HTPC for everything from home video playback to Blu-ray. I just found out that SPDIF is not the most capable audio connection available -- it can't do more than 5.1 in Dolby Digital or DTS. If I want HD audio such as DD+, True-HD, DTS-HD, etc., I've got to get onboard 9x00 mGPU from nVidia or a 4xxx ATI card, either of which can do LPCM over HDMI. (I'm using this table as a reference, which is pretty handy.)
Q1. Is that the only way to get HD audio during Blu-ray playback on an HTPC?
If the answer to Q1 is yes, then I'll be spending a bit more money than I thought. Intel mATX mobo with 9400 is $130 ish. So if I get that...
Q2. Will I need to spring for a higher end audio receiver that does HD audio decoding? (Or would the decoding already be done when the audio/video signal goes out over HDMI, so any receiver would work?)
If the answer to Q2 is yes, I'll be spending even more money, maybe $100 for an ONKYO TX-SR507 vs. the 307, say. (I've got speakers already, just need a new receiver, trying to decide on one.) Total, that's maybe $150 more than if I didn't care about HD audio. So...
Q3. Will I notice $150 difference in the audio quality? Are HD audio formats $150 more awesome than standard Dolby Digital/DTS?
Thanks in advance for the help.
