html and javascript help
MaluMan
183
i'm having some trouble running the following:
<SCRIPT LANGUAGE="JavaScript">
var thisList = document.myform.list;
checkCookies(thisList);
</SCRIPT>
<form name="myform" action="" method="post">
<b>TerpSpreadsheet Download Page</b><br>
<br>
<br>
*Please Note: You MUST have cookies enabled to view your previous downloads.<br>
<font size=4><b>
<pre> <input type="checkbox" name="list" value="1">&amp;#160;<a href="#" onClick="setCookie('all', '1');">TerpSpreadsheet 3.0 Package</a></pre>
<pre> <input type="checkbox" name="list" value="2">&amp;#160Source</pre>
<pre> <input type="checkbox" name="list" value="3">&amp;#160Java Files</pre>
<pre> <input type="checkbox" name="list" value="4">&amp;#160JavaDoc HTML</pre>
<pre> <input type="checkbox" name="list" value="5">&amp;#160Binaries</pre>
<pre> <input type="checkbox" name="list" value="6">&amp;#160Testing</pre>
<pre> <input type="checkbox" name="list" value="7">&amp;#160JUnit</pre>
<pre> <input type="checkbox" name="list" value="8">&amp;#160Coverage Reports</pre>
<pre> <input type="checkbox" name="list" value="9">&amp;#160Java Files</pre>
<pre> <input type="checkbox" name="list" value="10">&amp;#160JavaDoc HTML</pre>
<pre> <input type="checkbox" name="list" value="11">&amp;#160GUITAR Files</pre>
<pre> <input type="checkbox" name="list" value="12">&amp;#160Documentation</pre>
<pre> <input type="checkbox" name="list" value="13">&amp;#160Design Document</pre>
<pre> <input type="checkbox" name="list" value="14">&amp;#160Presentation</pre>
<pre> <input type="checkbox" name="list" value="15">&amp;#160Requirements Documentation</pre>
<pre> <input type="checkbox" name="list" value="16">&amp;#160User Manual</pre>
</font></b>
<br>
</form>
when trying this on IE i get the following errof: 'document.myform.list' is null or not an object
am i doing something wrong??? thanks for the help
