Which one is showing the right value? Is there another program to verify the HT speed? CPU-Z showed a lot of nice things, but not the HT speed. If nTune is right, there must be a bug in the BIOS (1004).
The HT multiplier in the bios doesn't work at all with my A8N SLI Deluxe. I am also using the latest bios. You are not the only one having problems. We await a new and better bios, I guess.
Thanks a lot for your help guys. I'll check out the programs to verify the HT speed, and await a new bios. I'm surprised there has been so many bios updates, and its still that buggy.
Btw, on two different systems with different PSU's, the mobo is repporting quite low voltages on all lines. Is this a bios bug as well?
I've had no voltage problems, and no Ntune problems. I use two power supplies, one for fans, HDs, and DvD-ROM (antec 350 watt), one for the MD and video card (OCZ 520w).
The only problem is that for example the 3.3v shows 3.2v etc. on two different setups. I thought the bios might be repporting wrong. I don't think you have to use dual PSUs to get stable voltages.
