Originally posted by: YOyoYOhowsDAjello
Originally posted by: Doggiedog
Originally posted by: MrScott81
buy a shelf and mount it behind the tv (assuiming the tv is reasonably close to a wall
That's exactly what I did.
Unfortunately, the speaker was a bit bigger than the shelf. Oh well.
Whoa, I'd be scared my stuff would fall of my tv when I cranked the bass.... but maybe it's just the angle that looks bad.
Before I replaced my wega, I used to have a center channel shelf on it
pic
I don't know how hard it would be to mod one of those to get a more extreme angle on the back. You'd have to extend the legs quite a bit, and by that time it would probably be pretty unstable. If I needed to do this (and I didn't want to do the shelf thing, which is the best option), I'd probably take my old shelf and then add some cardboard to the back cut to match the angle of the tv slant, so it would have contact all the way along and distribute the weight more. My center channel isn't very heavy (I'm not sure how much yours is) so a couple of layers glued together in two verticle panels on the right and left cut to match the tv would probably support it pretty well.
It probably wouldn't look too good unless you painted it afterward, but that's my ghetto stand idea
