Suck air in, generally speaking... assuming that means configuring the fan to blow down into the heatsink, instead of away from it. I've heard of a few heatsinks that are slightly more efficient the other way around, but not many.
Got 1 single fan on the Sparkle 250wt PSU blowing on the side and runs an Iwill with an AMD1700+ @2.1GHz so you should be safe. I think the AMD recommendations of the underneath Fan is no longer in effect now that the old TBirds are gone.
